I'm getting ready to order parts for an oil change, but I can't for the life of me figure out what size sump plug (and sealing ring) I need.
It's a Boxer with the DW10FUD engine (2016 2.0 bluehdi 130)
Is there an easy way to find this out without having to pull the old one first and measure it?
Or was this the kind of thing the old “Parts Service” on the forum used to help with?
Thanks!
DW10FUD sump plug size
sneakyfox
2016 Peugeot Boxer 2.0 bluehdi 130 (DW10FUD)
- x 8100
Re: DW10FUD sump plug size
Yes indeed, unfortunately that is not available to us at the moment but there are members with their own access and hopefully one of them will help you out.
You may be able to confirm it with the supplier in this ad: https://www.ebay.co.uk/itm/335732574153
PaulC5
- x 680
I always buy the sealing washer at the same time as the filter from the dealer parts department. The washers there have been lower cost than other sources.
sneakyfox
Thanks!
Thansk, I will write them to confirm. Not sure I can order from them though since I am in Italy right now.
In any case it would be great to get the number.
Thanks - but what is the dealer parts department?PaulC5 wrote: 03 Nov 2025, 12:05 I always buy the sealing washer at the same time as the filter from the dealer parts department. The washers there have been lower cost than other sources.
PaulC5
- x 680
Dealer parts department - you might know this by another name but it is your local Peugeot car dealer's own parts sales.
sneakyfox
sneakyfox
The OEM number on the ebay listing (0311.39) does bring up results on autodoc too which explicitly say they are for peugeot/citroen and engine code AHN(DW10FUD). And they are M16x1.5.
So I guess that looks promising. But of course finding out later that it doesn't quite fit would not be ideal! So if anyone can confirm the OEM I would appreciate it a lot.
