C5 II ES9A Cam Dephaser Removal
Assich
Unread post by Assich »
I am actually removing the upper cam blocks to re-seal. What a job. On top of which the timing belt idler has been leaking grease so quite a clean up to do. Definitely puzzled over these as can't find any removal/install instructions online. They are part number 0805F9 Delphi with 4no. 5 star security fixings, a hex key cover in the center followed by a screw below into the camshaft judging by the parts diagram. I'm looking for info on removing and how do I hold the cam in place. Then does the 4no. 5 point security screws all me to slacken the pully for timing belt install and tensioning?
1992 2.0i 8v Citroen XM Prestige Auto
2006 3.0i Citroen C5 Exclusive Auto
x 8149
Re: C5 II ES9A Cam Dephaser Removal
I don't know if this video will help you, I found it hard to understand so it may not but at least it might give you a guide :)
Assich
I was not convinced he did that by the manual. I did the ES9JS in the XM I had and that included loosening the rings on the cams and pulling them round locked cams to keep the timing spot on.
