Wire identification
drumvlado
Wire identification
Unread post by drumvlado »
Hi. I have a loose wire with a pin at the BSI and this can’t be good…
It seems to be from the 40 V NR / EP harness, but not 100% sure. As the print is missing a line on the right, I can’t be sure of the markings, it might be 1076A, 1078F etc… can someone help with this?
It’s the beige wire on the photo.
Reason: Image corrected
x 8165
Re: Wire identification
Can you confirm the Car model, year, engine, gearbox and RPO number and I will try and trace the wire if it is pre 2013. If later you will need help from a member with their own access to the live Servicebox system. :)
