Citroen Dispatch won't unlock
Frank675
Unread post by Frank675 »
Hi all, i have a 2015 Citroen Dispatch and the drivers door won't unlock. I use a key as i don't have a fob. I can unlock the rear door but that doesn't unlock the front doors. I have reached through a gap with a pole to press the unlock button near the radio but it doesn't unlock the front. When i turn the key in the door it will lock but nothing happens when i try unlock. Does anyone have any ideas as i'm stuck without the van. Thanks all!
x 8082
Re: Citroen Dispatch won't unlock
Can you use the key in the passenger door? :)
x 1056
Unread post by wheeler »
Im guessing it has a bulkhead? Can you unbolt it?
Have you tried pulling the interior door handles with a rod through any gaps? If it was not locked with a remote then hopefully its not deadlocked.
The lock button on the dash normally goes dead a few minutes after locking the van.
