i need help with rain sensor retrofit please
lead
Unread post by lead »
good morning, I'm trying to activate the rain sensor on my peugeot 208 2024 active model which doesn't have one, I bought the original NEW compatible spare part, I attached it to the glass without problem and to the already existing wiring, then with the coding tools I activated the 236D rain / light sensor zone in bsi on the network but I encountered several problems, first of all the rain sensor doesn't seem to work because when I activate the automatic windshield wipers by lowering the lever on the steering wheel, the windshield wipers are activated with a random stroke every 10 seconds even if the windscreen is dry and if I try to throw water on it nothing changes and it remains every 10 seconds (as if the sensor were not working but it is connected because it is detected in the network with serial number etc.) the second problem that appears to me is that the automatic lights that I already had are completely blocked thanks to the twilight sensor on the dashboard, it is as if the rain sensor took control of the automatic lights but not when it works it always leaves them on with the low beams, I hope I have explained my situation well and that someone can help me resolve it
x 8085
Re: i need help with rain sensor retrofit please
I'm afraid your car is far too new for me to know anything about it!! :)
