Hello, can I find out what extras my car came with when it left the factory?
VIN:VF3**************[VIN obfuscated, can be read by forum staff]
Hello, is it possible to check the VIN number?
emirock
- x 5671
Re: Hello, is it possible to check the VIN number?
Please see my PM to you regarding this.
- x 1056
Here you go
Vehicle characteristics
308 (T9) 5 DOOR ESTATE 1.5 BlueHDi 100 (DV5RD 75KW Euro 6.2) STT TYPE 6-SPEED MANUAL GEARBOX
Vehicle family 308 (T9)
AS/RP N° 15730 89 1 0275
Warranty Start Date 11/05/2020
Engine serial number 10 Q4DV 0014095
BER e2*2007/46*0405*27
P4A 9835919299
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 308 (T9)
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL ACTIVE
ENGINE DV5RD 75KW 1.5L DIESEL
TRANSMISSION STT TYPE 6-SPEED MANUAL GEARBOX
PAINT TYPE METALLIC LACQUER PAINT
BODY COLOUR KTV - BLACK PEARL PAINT
INTERIOR TRIM TYPE CLOTH MECO G395 + RIMINI G275
UPHOLSTERY COLOUR "FM"
GEARBOX (CHARACTERISTICS) MB6HW
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW MID-LIFE
ENGINE (TYPE) DV TYPE ENGINE
PRE-EQUIPMENT FOR CONVERSION WITHOUT PRE-EQUIPMENT FOR CONVERSION
OTHER BADGE, " MISC. " STYLE
TRIM LEVEL ACTIVE
Fuel supply-Engine
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAP STANDARD FUEL FILLER CAP
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.2 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1500 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER ABOVE 50PPM
FUEL TANK FUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTION NORMAL FUEL CONSUMPTION OPTIMISATION
COOLING MOTOR RADIATOR 28DM2-18F1
CRANKCASE GAS CIRCUIT HEATING WITH SUMP GAS CIRCUIT REHEATING
POWER VARIATION (ENGINE) 75KW - 250NM
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION EURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 X 2-SPEED FAN 95W AERO DYNAMIC FLAP
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIO AXLE RATIO 19 X 72
WHEEL STYLE 16" NON-DIAMOND TOPAZ WHEEL RIM
CLUTCH HYDRAULIC CLUTCH
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) UNREINFORCED 205/55 R16 91H TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
GEARBOX TYPE MB6 MANUAL GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR DIAMETER 22 HOLLOW
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) LOW POWER SINGLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORN STANDARD
AERIAL SHORT ROOF AERIAL
REAR SPOILER WITHOUT REAR AERODYNAMIC SPOILER
SIDE MOULDINGS (DIMENSION) WITHOUT + STYLE SIDE SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
EXHAUST TAILPIPE WITHOUT EXHAUST TAIL PIPE
UNDERBODY SHIELD FRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET STANDARD SCREEN WASH JET
EXT. LOAD RETENTION RING (ATTACHMENT) WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXTERIOR MIRROR+DIODE
SPLASH SHIELD FRONT STANDARD MUD GUARD WITH FOAM
ENGINE BAY SOUNDPROOFING BULKHEAD + BONNET + GMP SOUNDPROOFING
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER WITH REAR WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK DOUBLE PILOTED AIR INLET CLOSER
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER B COL FR BUMPER+CHROMED STRIP AND B COL RR BUMPER
MUDFLAP AERO FRONT MUD GUARDS
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
PANORAMIC VISUAL AID WITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
SPARE WHEEL SPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIES BODY COLOUR EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
GLASS (APPEARANCE) TINTED + DARK-TINTED RR WINDOW GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
HANDS FREE ACCESS AND STARTING WITHOUT HANDS-FREE ACCESS/STARTING
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER WITHOUT CIGAR-LIGHTER
BLIND SPOT DETECTION WITHOUT BLIND SPOT MONITORING
REAR SEAT ARMREST WITH REAR SEAT ARMREST
INT. LOAD RETENTION WITH INTERIOR STORAGE
LUGGAGE COVER SCREEN
REAR SEATBELT 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELT RETRACTOR ALARM DRIVER + PASS S/BELT
ASHTRAY WITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR FLOOR GEAR CONTROL
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MIRROR LINK WITH MIRROR LINK
INT. TRIM AND EQUIPMENT VARIATION WITHOUT ACCESSORIES SOCKET
MISC. INT. LAMPS FRONT SPOTLAMP + REAR INTERIOR LAMP
LOAD SPACE TRIM MAT + BACK + SIDES CARPET
INSTRUMENT PANEL (CHARACTERISTICS) INSTRUMENT PANEL WITHOUT MATRIX
DOOR TRIM SATIN CHROME DOOR TRIM DECORATION
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING WITH ISO RR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
RADIO CONTROLS REMOTE RADIO CONTROL
PASSENGER COMPARTMENT SOUNDPROOFING SOUNDPROOFING (PASSENGER COMPARTMENT) BULKHEAD 2.8 KG
FRONT PASSENGER SEAT HEIGHT CONTROL PASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT MANUAL DRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
FRONT SEAT ARMREST CENTRAL ARMREST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM NAVIGATION 2 COLOUR SCREENS
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY DGT7C SCREEN FRONT DISPLAY
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGE W/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
REAR LOAD FLOOR WITHOUT REAR LOAD FLOOR
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT CAB PROTECTION PANEL
FRONT SUN VISOR DRIVER+PASSENGER SIDE WITH CARD HOLDER+INSCRIP
WIFI WITH WIFI
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
CARPET COVER W/O CARPETMAT
LOAD SPACE STORAGE BOOT LATERAL TRIM STRAP
TUNER RADIO MONO RADIO TUNER
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
FLOOR MAT W/O CARPETMAT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL FULL FLOWER LEATHER ST WHEEL
SEATING ASSOCIATED VARIANT LOW
SEAT LUMBAR SUPPORT (OPERATION) MANUAL LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET 1 USB SOCKET
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORN STANDARD
BATTERY BATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTOR STTD STARTER
SPECIAL LIGHTING FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING MODIFIED ECONOMY ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STYLE
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS) CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES STANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET SINGLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
DOOR SEAL IMPROVED DIRT-EXCLUDER SEAL
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
SLAVE CONTROL UNIT BSI + COM 2008 + POLY SOUND
P4A 9835919299
General information
TRIM LEVEL ACTIVE
TRIM LEVEL ACTIVE
Fuel supply-Engine
CAPACITY 1500 CM3
Body fittings
HORNS HORN STANDARD
Interior fittings
WIFI WITH WIFI
Electrical
HORNS HORN STANDARD
Miscellaneous
LABEL WITHOUT LABEL
emirock
