diagbox download link ?
Rhothgar
- (Donor 2026)
- x 221
Re: diagbox download link ?
Spent the last half hour trying to stitch the Diagbox Part 1, 2 and 3 rar files together from the Mega link but cannot work out how to extract them and burn to a disc.
It seems that the files have duplicate names in each rar and should be appended but Winrar doesn't want to play.
Trying to install Diagbox on PC as laptop is stuffed. Not having a great day...
- x 6945
You just open the first archive file with Winrar and extract it to your desired location. Winrar will automatically open the other files as required and you will end up with the contents of the archive extracted.
Rhothgar
- (Donor 2026)
- x 221
Yes. That is exactly what I thought should happen.
However, I only downloaded the Diagbox 7.02 Parts 1, 2 and 3 from the archive as I didn't want all the updates.
I think the last time mine was updated it was to 7.24 only though I cannot be 100% sure.
I have now downloaded the whole folder as a zip and am trying to extract that way. It now has 7 rar files in. I feel if I extract part 1, it will just result in the same problem. Parts 2 and 3 have the same file names in.
Wish I could find my original disc that came with the Lexia.
OnlinePaul-R
- x 1938
Are you sure that the filenames are exactly the same? Usually with split files the main name is the same but the three (or four) character suffix is different and, indeed, increments by one to show the order of unwrapping. I.E.
filename.rar
filename.001
filename.002 etc
If the rar has seven components then you should download and extract all seven parts and then disregard the parts you don't want. If all parts of the rar are not present then the unwrapping program will be confused.
filename.rar
filename.001
filename.002 etc
- x 6945
Exactly - the individual content of a RAR archive will appear to contain the same files - because it is an archive. You cannot extract separate parts from a 'spanned' archive!
You need to complete the whole extraction process with ALL the separate RAR files that make up the spanned set, open up the first file - and allow the complete archive to be decompressed. Then when that has fully completed, you can do as you please.
Mesersmith
Is there somewhere a newer version of diagbox software?
I really need it.
I really need it.
Citroen C5 Aircross 1.8 hybrid, 2021
Citroen C5 X7, 2.0 HDI, automatic, 2010
România, C?l?ra?i
România, C?l?ra?i
OnlinePaul-R
- x 1938
Mihael_M
- x 37
https://guiapsa.foroactivo.com/t2128-05 ... s-18-12-24
This site is in Spanish but is easily translated. The installation is easy and then the language can be changed. Works directly on all Win 64.
notinserviceuk
- x 5
thanks for that i give it a go
OnlinePaul-R
- x 1938
I think that’s the same site that I linked to.
peyvey
this is more up to date in that spanish forum you have choise of download for free or for 20 Euros
I chose the free version but maybe i opt for the paid version later
https://guiapsa.foroactivo.com/f59-diag ... -opel-y-ds
Roman Citrus
New to this stuff
Hello fellow French car guyz!
Wanted to ask questions about the diagbox and lexia. i myself just got a C4 vts 2005. and as i own already a 1 more citrus i thought lexia/diagbox would be a good investment as am more of a hands on guy anyways. in my country we have for sale a *Citroen/Peugeot Diagnostic Lexia 3 PP2000 WIFI* and would need maybe some directions, like what application i need. my two cars are 2005 and 2007. would diagbox be better? or Lexia 3?
Big ty for any answer!
Kees
- x 148
Lexia is integrated into the Diagbox!
Roman Citrus
I see, thank you Kees!
Wanted also to ask, if it would run on win 11? as the newer versions come out the one i buy comes with diagbox 9.91V and i dont know if i should get a separate pc for it and then install a win 7 or xp even.
also been reading something like full chip, and partly supported... how would i know if the one i want to buy is full chip one? (i suppose the *chip* means how much it can see about a car or control) Like the ad says that it comes also with K-Line multypleksorit, CAN-BUS, SAE J1850, ( PWM and VPW)
wildatsun
- x 4
Hi is there any update to this, working link etc?
I have a 2013 Lexia but it doesn't seem to want to talk to stuff on my 2015 B9.
Thanks.
Thanks.
