Battery replacement for Citroen C4 Grand Picasso 1.6 BlueHDI 120 Diesel (series 2015-2018)
Apollo
Re: Battery replacement for Citroen C4 Grand Picasso 1.6 BlueHDI 120 Diesel (series 2015-2018)
Unread post by Apollo »
:rofl2: Thanks for the fast reply looks like citron and the websites haven't got a clue what to put into that car?
If you read the above thread then all the paperwork says to replace it with an EFB battery and the websites providing batteries including RAC and AA also when using the registration checker recommend both EFB and AGM
Is it possible to use your contacts to confirm exactly what type of batteries are supposed to go into that make and model of Citroen?
Would you recommend that I email them myself and provide a link to the thread?
The PSA label was a picture from the car and that says EF on it the websites also confirm that EFB is ok and the battery that came with the car appears to be EFB as well
If you are able to clarify the mixed messaging that will be wonderful and much appreciated
Thank you for your help so far look forward to seeing if you can resolve it!
I've ordered the Toptom battery tester which is arriving in a few days and we'll run tests using that as well as the original battery tester above again and post the results hopefully it should all be giving good results by then
If it does turn off that it has to be replaced with an AGM battery then I will email Tanya batteries as well as a number of other places and ask them what is going on!
x 3298
I would suggest that you consider signing up to the GSF newsletter (on their website). Once you do so you become eligible for discounts of up to 65%. The battery in my C5 became very weak, and needed replacing. I got a Yuasa battery, with a 4 year warranty (that would have been close to £300) for under £99.
mmatin
(Donor 2022)
Unread post by mmatin »
GiveMeABreak wrote: 05 Nov 2023, 22:16
mmatin wrote: 05 Nov 2023, 16:32
GiveMeABreak wrote: 01 Nov 2023, 13:57 If you pop your VIN up I can see what you are supposed to have. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Hi Marc,
Can you check for VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] what battery is installed.
Thanks!
Mario
Hi Mario
Battery type is AGM
(1) 12V Battery
Original, (L3-70AH-760A-AGM) part: 9678006180, £303.91
Cheaper Alternative, part: 1620012780, £215.15
Thanks Marc,
After replacing the battery is there anything to be done in diagbox?
Mario
Mario Matin
x 6948
No, because you are replacing it (I assume) with the correct type and rating. :wink:
Just follow the BSI Reset / Battery Disconnect / Reconnect Procedure and be aware that it can take 24 hours for the climate control system to fully initialise once the battery has been disconnected.
x 1947
The only reason for going in would be if someone had previously put a different type of battery in and changed the details to suit.
Apollo
Thanks I'll have a proper look at these posts when I get home tonight
Stop starting is working fine I've worked out that it doesn't work when the air conditioning was on or the windscreen wipers are working or are on automatic
This makes sense as a handbooks etc say that they need the engine running to provide sufficient power to work
So in summary I I'm being advised on the forum it should be an AGM which I believe
The online websites and the PSA label say it should be an efb
Since it has already been installed and appears to be working fine I'll continue to use it for now I will email them and seek clarification
Suspect what may have happened is that as a company they have switched over to installing AGM batteries even when the car was installed with an EfB battery
I'm basing this on what one of the reception staff at the stellantis dealership told me when I was getting it serviced a couple of weeks ago that they were only installing AGM batteries in all models and makes that had stop start technology
Thank you all for your help so far I will keep you updated with regards the battery tests and any replies I get from stellantis over the next week or two
x 1947
An AGM battery has a higher specification than an EFB battery and can be used as a replacement. EFB batteries should not be used to replace an AGM battery.
Whether or not the car has been informed of this change, or even if there's an option for AGM as opposed to EFB, I can't say.
x 1057
Unread post by wheeler »
If in doubt use AGM.
The tyre pressure label will show what it left the factory with. Specification can change though, its possible that PSA could decide that EFB is not good enough after seeing X amount of early failures so change the spec to AGM.
If i remember right this actually happened with VAG group cars 5 or 6 years ago, they had loads of EFB batteries failing when still under warranty so were getting replaced with AGM.
Apollo
Quick update
The Tanya EFB battery that I installed above has worked without issue
and the stop-start works without a problem
had a fuel issue today that I will post separately in another thread
Adam1984
Unread post by Adam1984 »
Hello Marc,
If I provide my VIN can you check what battery I need please as I am conflicting on various websites about EFB or AGM
x 8161
Hi Adam, Marc is no longer active on the site and you are less likely to get an answer from someone else if you keep raising the same issue on different threads, it simply confuses the situation. Stick with your 'best battery' thread and keep it simple please. :)
