Coolant leak - 2000 / 206 1.6 8v
cosmosred98
Unread post by cosmosred98 »
Hello Everone, The pipe I've marked in orange has a leak. What's the exact name of this pipe and how difficult do you think it would be to replace it? I'm too far away from the city and I'm thinking replacing the pipe by myself.
x 8110
Re: Coolant leak - 2000 / 206 1.6 8v
Are you referring to the pipe which is part of the bracket which I have marked green on this picture? or do you mean the hoses connected to it? Secondly can you post a wider angle picture so that it is clear which part of the engine we are looking at. :)
cosmosred98
mickthemaverick wrote: 15 Sep 2025, 16:14 Are you referring to the pipe which is part of the bracket which I have marked green on this picture? or do you mean the hoses connected to it? Secondly can you post a wider angle picture so that it is clear which part of the engine we are looking at. :)
no, Behind the green one closer to engine.
x 1942
Perhaps if you could push some of the wires to one side and take another photograph it may make which pipe you're referring to more obvious.
cosmosred98
Paul-R wrote: 15 Sep 2025, 18:12 Perhaps if you could push some of the wires to one side and take another photograph it may make which pipe you're referring to more obvious.
That one but u right not that clear in the picture. Tomorrow i try take more clean picture.
