eylos tank
Biff1612
eylos tank
Unread post by Biff1612 »
is the eylos tankrefillable on C4 grand p[casso 1.6 hdi 2011 its under car near o/s rear wheel hid by a load of plastic
x 8087
Re: eylos tank
If it is a pouch you replace the pouch, if it is a tank you refill it with an eolys kit which includes filler pipe etc. Either way once done you have to go into the ECU and tell it to reset the counter to 0 using Diagbox or other high end diag kit. :)
x 1938
Re: eylos tank
All Eolys tanks are refillable either directly, from a bottle and tube, or using a replaceable pouch depending on type.
