- x 1074
I'm assuming you mean faux fur and not some poor animal.....
Champion of Where's CitroJim
- x 8134
Have you checked the wiring to the injectors Matt?
- x 2356
Not specifically - will have a look. Hasn't been disturbed in this area, but will check.
A plug in with Diagbox is probably next. I'd expect a fault code on injector wiring continuity - following Mick's hypothesis - perhaps??
Typographical errors abound, no animals were harmed in the creation of my waffling - though the phone's "corrections" at time puts it's "life" in a perilous state at times!
darbuck
- x 289
Hi Matt get some live data as you are cranking but before you do disconnect all the lines to the injectors and crank it over to purge air from the high pressure side.check the low pressure side first for air bubbles.
Darren
- x 2356
Not had chance/enthusiasm (to sit in a hot car, baking in the sunshine!) for a diagnostic session as yet, instead did some car moving and then a wash off. Complete with help from the boysdarbuck wrote: 11 Aug 2025, 07:05 Hi Matt get some live data as you are cranking but before you do disconnect all the lines to the injectors and crank it over to purge air from the high pressure side.check the low pressure side first for air bubbles.
And just showing a foible of the torsion beam suspension.
Apologies for the shorts!
Huskyxantia
- x 918
Just watched your videos matt, I feel there's some great videos to come ! Well done my friend
Husky.
- x 8134
Morning Matt, it's not the shorts you should be apologising for!!
- x 2356
Thanks Husky!
Well, yes - well I'm sorry for what the shorts do not obscure!mickthemaverick wrote: 12 Aug 2025, 09:48 Morning Matt, it's not the shorts you should be apologising for!!![]()
- x 8134
A quick thread bomb:
Just a promotional post to make sure anyone interested knows about the forthcoming trip plans which can be found at:
viewtopic.php?p=847400#p847400
- x 2356
Letter received yesterday, images below for interest.MattBLancs wrote: 08 Aug 2025, 09:40 Peugeot site, using VIN states:
https://www.peugeot.co.uk/tools/recall-campaigns.htmlYour vehicle has a Recall campaign, please contact your authorised repairer to have the campaign carried out free of charge.
To confirm: this is rear seat belt anchorage points (not the Takata air bag issue)
- x 8134
I guess that Peugeot had the idea of giving rear seat passengers the chance to fly into the front to sharre the benefits of the exploding airbag in the event of a crash! Cunnng way to ensure there were no witnesses!!
- x 5672
Just seen this
Not going well for Stellantis.Car fire safety recall hits 28 different models including Fiat, Peugeot and Vauxhall - is YOURS at risk?
- x 8134
I'm beginning to be glad that our household cars are all Japanese!!
- x 2356
Quotes from the article
linked to a potential risk with the high-pressure fuel pipe in models produced between 2023 and 2025 with the 1.2-litre petrol engine mostly in mild-hybrid variants.
This powertrain is shared across various models in Stellantis' range.
The risk of loose nuts securing the pipe has been identified and could potentially lead to leaks, and, 'in a worst-case scenario', fire in the engine bay, the car giant states.
The recall is voluntary - meaning the Driver and Vehicle Standards Agency hasn't forced Stellantis' hand to resolve the issue - and has been prompted by 11 reported cases of cars catching fire in France.
Interesting, thanksSome 2023-2025 Peugeot, Citroen, DS Automobiles, Vauxhall, Alfa Romeo, Jeep and Fiat vehicles may face fuel leakage at the high-pressure pipe between the high-pressure pump and the rail due to loosened nuts.
'This can potentially lead to higher fuel leakage consumption and, in a worst-case scenario, to occurrences of fire in the engine.'
They added: 'Stellantis already started the proactive outreach to vehicle owners, asking them to contact the dealer network to schedule an appointment.
'The rework consists of retightening the nut connections on the high-pressure pipe and the screws of the rail. It takes less than half an hour and is free of charge.'
- x 3565
It'd be interesting to know what the actual root-cause of the fire related issue is. Is it down to cheaping out on parts, poor design, operator error on the production line, suppliers cocking up, or something else ? Was it actually a reasonably foreseeable issue, or is it a bit of an unusual issue ?
