CITROEN C4 CACHET 1.6 HDI 2008 - REAR INNER BEARING DIAMETER?
Citroenique
Unread post by Citroenique »
Hi
Need to change a rear bearing on the C4. Ive been told it has either a 25mm or 30mm inner diameter for the bearing. Can't find any info on which size it is short of dismantling rear wheel assembly and measuring it. Does anyone know what the size is or where I may find a definite answer say for example with the vin?
Many Thanks
x 7789
Re: CITROEN C4 CACHET 1.6 HDI 2008 - REAR INNER BEARING DIAMETER?
If you post the VIN, which will be masked from general view, there may be a chance of someone finding the information for you. Unfortunately the forum has currently lost access to the PSA database, hopefully not for ever, but we can sometimes help anyway. :)
Citroenique
Hi,
Thanks for the tip!
For anyone who may be able to help here is the vin: VF7**************[VIN obfuscated, can be read by forum staff]
