Hello everyone.
Am looking for a copy of the CITROEN 969013 alarm instruction manual. I have the alarm itself but instructions have since faded away and cannot make it out. Thanks,
Dragon
969013 Alarm instructional manual
- x 8086
Re: 969013 Alarm instructional manual
You may find some information here: https://www.manuals.co.uk/citroen/c3-2022/manual?p=31
DragonofYoRHa
Hi, apologies.
I should have specified I’m looking for the DS3 installation instruction manual only thing I have is a sheet saying the Act number U9690.13
- x 8086
In that case try this: https://www.ds3manuals.com/ds_3_alarm-1890.html
DragonofYoRHa
Hi,
Looked at the link you had sent but not seeing in the website how to install the factory alarm. Maybe you know where to find the workplace installation manual?
Thank you,
Thank you,
- x 8086
Aah, I was going on your initial request for the instruction manual, I doubt an installation manual will be generally available as it would compromise the security of cars with it fitted. I'd suggest you contact whoever you got the system from and ask them for installation information.DragonofYoRHa wrote: 05 Aug 2025, 10:36 Hello everyone.
Dragon
DragonofYoRHa
mickthemaverick wrote: 05 Aug 2025, 15:51Aah, I was going on your initial request for the instruction manual, I doubt an installation manual will be generally available as it would compromise the security of cars with it fitted. I'd suggest you contact whoever you got the system from and ask them for installation information.DragonofYoRHa wrote: 05 Aug 2025, 10:36 Hello everyone.
Dragon![]()
Hi,
I did not even think about this way. It makes sense I suppose. I am awaiting a response from the seller but I suspect he does not have it. I have a load of cables and the alarm itself in the original box from PSA yet no installation manual.
Without it’s honestly useless, there is a link to a website that no longer exists from PSA and I hoped someone on the forum would know where to find a digital copy for the workshop installation. I haven’t a clue where all the cables go or even the Alarm itself is located in the car
P.s. I did get one when I bought a wiring loom for the towbar, that was also original from CITROEN.
- x 8086
You may still be lucky from another member with the right contacts but that is about all the advice I can give you. Good luck
Pasi80
Hi.
Do you know where to get Citroen C3 1.2, 110 hp (Gen. III Phase I, 2018) workshop manual? I mean the manual they use in Citroen maintenance? Need one
