x 5679
I used to use those tree-based navigation aids but for a long time now I look at the information, set off and wonder where I am going, all stored information evaporated when I used to be able to drive the length of the country with one consultation of the RAC navigation aid.
I sometimes forget where I am going locally and end up at work instead of the shops. Work I retired from seven years since and is no longer there.
x 8440
mickthemaverick wrote: 30 Jul 2025, 07:59 Still not instant availability though Jim, and on a long journey you'd have to stop at various times to recharge your battery!! :-D
Ahh, got that covered Mick, I maintain backups - on paper ;)
myglaren wrote: 30 Jul 2025, 08:21 I sometimes forget where I am going locally and end up at work instead of the shops. Work I retired from seven years since and is no longer there.
Been there, done that Steve! It's quite normal :wink:
x 2367
Unread post by MattBLancs »
Few questions I need to work out / research the answers too:
C5
  • are the high pressure injection pumps coded to the car - or is there anything else I need to know ahead of buying a second hand pump (likely a land rover one given matching part numbers)
  • Has anyone dived into a pump? In my current hypothesis of the low pressure "lift pump" portion being at fault, is there anything internally I could stand a chance at fixing (e.g. non return valves or similar)?
  • Am I wasting my time trying to get this running? Is anyone realistically going to want to take it on? (Current plan is aiming at MOT if I can get it running again as a viable usable car is better prospect than a big paperweight with lovely suspension)
Grey 308 SW
  • I need to organise a new key for it (currently only one)
  • I need to understand if soldering in new key buttons is viable for some amateur waving a soldering iron.
  • I need to get my head around changing some of the various gaskets I've bought and work out when I'm tackling its oil leak
x 8162
What year, engine, gearbox, spec and mileage is the C5?
x 2367
mickthemaverick wrote: 01 Aug 2025, 22:21 What year, engine, gearbox, spec and mileage is the C5?
2009,
2.2 HDi bi-turbo 173 bhp (and 370 Nm) flying machine :-D
Manual 6 speed (sorry Mick!)
153,529 miles
Spec wise it is an Exclusive, so has the hydropneumatic "proper" suspension, part leather electric ( 8way??) adjustable seats.
It has the full length "moon roof" which definitely helps lift a predominantly black interior.
It makes do with the basic RD4 CD radio and little MFD screen (which had the usual "fine when it is nice and cold in winter but turns all black with increased temperatures".
Cruise control, electric boot, dual zone climate, lights everywhere including automatic door pocket Illumination, front and rear foot wells etc.
Timing belt done when I got the car (will confirm date and mileage in a bit)
Steering rack all ok when last checked but put an up to date photo up when I get chance.
Functional wipers :)
Two keys
x 2367
MOT history for background reading:
https://www.check-mot.service.gov.uk/re ... calls=true
Apart from a few drop links it's previous owner(s) didn't seem the type to check the basics ahead of the tests so lots of silly failures for blown bulbs variously.
Road tax / road fund licence is probably biggest thorn in its side, £305 a year from memory (do would guess it'll be £5-£10 more today)
x 8162
Thanks Matt, but you read my mind so no go for me!! :)
x 2367
mickthemaverick wrote: 02 Aug 2025, 09:12 Thanks Matt, but you read my mind so no go for me!! :)
No problem Mick, there's lots of them Auto, I'd guess the manual variants are the minority for the C5 X7s.
Oh, I've a spare pair of the entwined twin turbos too that could go with the car
x 2938
Your HP pump problem may not be the pump, the last one I did with similar problems I took the pump off and stripped it, could find nothing wrong with it or the other fuel control gadgetry and all bleeding attempts failed.
Got the car started by feeding Easy-start several times into the intake then it finally self bled and continued to run.
x 2367
Gibbo2286 wrote: 02 Aug 2025, 10:09 Your HP pump problem may not be the pump, the last one I did with similar problems I took the pump off and stripped it, could find nothing wrong with it or the other fuel control gadgetry and all bleeding attempts failed.
Yes, I've read of such issues getting it to go, and had much trouble getting mine going in the past. This time it has had a good long tow start (which did do the trick when I'd issues previously) engine spinning around a thousand rpm but no joy this time.
x 2367
Perimeter sealed at last following my hacking a hole in it a good while back.
Here:
viewtopic.php?p=838076&hilit=Waste#p838076
I have used "squirty foam" a good few times so am aware of it's high rate of expansion.
Today's lesson was:
"If you buy cheap, over it's "best before date" squirty foam it may initially be reluctant to leave the tin."
When it does finally get going however....
Spoiler: show
Oh well, trim back once it's dried!
x 8440
That spoiler... :lol:
x 2367
Cheeky cheap best offer accepted on a second hand HP pump, hopefully cures the C5
Land Rover Freelander 2 2.2 Diesel High Pressure Fuel Pump 9683268980 0445010139
Spoiler: show
up for (rather oddly specific!) £57.87,
my best offer, of £45 I thought was a good starting point for a discussion - surprisingly accepted quite quickly.
That squirty foam (and the rest of the tin full applied around the insulated plasterboard we stuck up yesterday) will get trimmed back tomorrow :)
x 3565
The rather oddly specific price is due to the way ebay charge for their services now. The seller used to pay ebay for selling, but now the buyer pays - so the seller would have put it up for (I think) £55, but ebay then add on their charges to make the selling price £57.87.
x 2367
bobins wrote: 03 Aug 2025, 19:55 The rather oddly specific price is due to the way ebay charge for their services now. The seller used to pay ebay for selling, but now the buyer pays - so the seller would have put it up for (I think) £55, but ebay then add on their charges to make the selling price £57.87.
Ahhhh! Makes sense, the did wonder what on earth everyone was doing with their prices recently! I recall being notified about the changes but did not realise how it would materialise :)
