What's left of the clutch/pully is a fragment of the clutch plate held by a nut (if I understand correctly), and whatever I tried, I was unable to remove the nut, even after a lot of attempts, and greaser / colling spray. Is there something special about this nut? I've seen YouTube videos that explain you have to properly hold the plate to unscrew the nut. Since I don't have the full plate, I tried holding whatever was left with a visegrip, a pipe wrench and more, but the nut didn't move at all.
More information. After the clutch/pulley broke, the A/C compressor looked like this:
The parts of the clutch/pulley fell onto the bottom mud cover, and here's how they look like after I collected (most of) them:
After so many attempts to hold the plate with a visegrip, the plate became almost rounded, I actually used a hacksaw to cut away some part of the plate base to get a better grip (I guess I went too far) and now the nut started losing some of its hex shape from all the turning, hammering, etc. Now it looks like this:
Please advise - what can I do?
