ECU AND BSI CODE ERROR
Dmayne03
Unread post by Dmayne03 »
Does anyone know a company that can unlock the ECU for a Peugeot 308 2009 1.4vti when reading live data the ECU unlocks then 10 seconds later it locks and says it can not get the BSI code error
x 8086
Re: ECU AND BSI CODE ERROR
Have you asked a Peugeot dealer? :)
x 1938
Is this affecting the vehicle at all? Rough running, hesitancy, failure to start, etc?
Dmayne03
It cracks but does not start
x 1938
How long has it been like this?
Dmayne03
since December 2024 when the car just cut out when running
ozvtr
x 246
Unread post by ozvtr »
The engine ECU does not poll the key once the engine is running. So the engine would not have cut out because of a security failure, as appears to be the current problem.
A CAN BUS failure may cause both faults. Or an out and out failure of the engine ECU.
Are there any fault codes from any of the other ECU's?
Any other clues?
