Peugeot 206 CC multiple faults
Tayfun
Unread post by Tayfun »
Hello
I have for a while now a 2003 Peugeot 206 CC, VIN No.: VF3**************[VIN obfuscated, can be read by forum staff]. The car only has 130.000km, it has been sitting for 8 years in a barn. I bought it in the winter and had in the meanwhile the rust issues fixed, car got new tyres, new brake discs and pads, new spark plugs, new cabin, air and oil filters and the oil changed, new coolant and new battery. Bought some new speakers that will be installed. Car runs and drives but not optimum. It has several faults, that have been read with the Launch X431 tool. If you guys could give me some hints what to look at, I would really appreciate it. I guess the first faults must have to do something with the wiring.
Reason: Images fixed
x 8080
Re: Peugeot 206 CC multiple faults
Did you clear all faults after powering up for the first time and then run a global test or were those faults present straight away? My point is they may be historic so I would clear them all and then run the engine to warm up and re scan. That will give a picture of how things are now. :)
Tayfun
Hi
Yes they’ve been cleared but come back as is. After last clearance the Airbag fault came up, which wasn’t present before. I can try clearing them now again and see what will happen.
Tayfun
I cleared the faults and the exact same ones came back.
