508 cooling fan only runs on slow speed
Akos
Unread post by Akos »
Hi all!
I have a 508 2012 2.0 hdi.
When AC is on, the cooling fan only runs on slow speed. So when car is stationary and there is no wind, the AC is not cold enough. Gas is filled, not leaking, changed the relay, changed the cooling fan, still goes on slow speed, when it should be using second/fast speed. Did anyone have the same problem?
x 8065
Re: 508 cooling fan only runs on slow speed
It is probably the fan resistor which was the usual cause of fans only working on one speed, it looks like this:
https://www.ebay.co.uk/itm/254192812045 ... ntid=87779
There are a fair number of videos about it on Youtube. :)
Akos
It's also called the relay. I have changed that with original part. Thanks anyway!
