C5 X7 Changed crank sensor now wont start. Help!
x 3565
Re: C5 X7 Changed crank sensor now wont start. Help!
Highly unlikely, but check the fuse protecting the OBD port hasn't gone pop !
x 1240
Unread post by Peter.N. »
On three cars? possible but I would think highly unlikely.
KennyW
x 165
Unread post by KennyW »
Peter,
Have you checked the crankshaft wiring. If this is exposed causes lots of problems.
Kenny
C3 1.4 petrol (SWMBO)
x 1240
All looks OK have given it a good pull at the plug but nothing moves, Looks in good nick too, the plug is quite easy to remove do doesn't stress it a lot.
x 1240
Any ideas what the voltages should be on the plug pins?
KennyW
x 165
Peter,
I can't remember but it will either be 12 volts or 5 volts. I'll need to find my own thread about the sensor to see if I put measurements on there.
Just checked my old thread confirmed 5 volts.
Kenny
x 8165
OK Peter IR on the way on Thursday. Thunderbird 2 due to touch down mid morning!! :-D
I'm posting this link to the OBD2 pinouts here for ease of access: https://pinoutguide.com/CarElectronics/ ... nout.shtml
x 1240
Thanks for that Mick
x 8441
mickthemaverick wrote: 14 Jul 2025, 13:45 OK Peter IR on the way on Thursday. Thunderbird 2 due to touch down mid morning!! :-D
Peter, whilst I think of it ;) So that I can run my Diagbox, can you please arrange for a mains supply to be very close to the car... Although my Diagbox laptop has a new battery, it's not that brilliant - but then, what can you expect for a fifteen quid eBay special!
x 1240
Power in garage and extension leads Jim, just inside main door on the right, where the batteries are.
x 8441
That's great Peter 👍 Looking forward to seeing you tomorrow 😀
