RH drivers window switch module 2008 207cc convertible
u8myufo
Unread post by u8myufo »
Have had some problems for a while now when operating the drivers window, intermittent either way or nothing at all. If putting the roof back up the passenger windows go up as does the drivers quarter light window,but sometime the main drivers window wont. I have had the switch apart and cleaned the circuit board. It worked fine for a while but back to playing up again. I have sourced one from a scrap dealer, he sent me a pic of the block connection (first image) as I know there are variants. The fitting is identical but what I notice is that whilst his has nine pins on one row mine only has eight (second image)
Can anybody shed some light as to whether that will cause an issue or not, or what that extra pin is for? I only ask as it`s just over an hour away to the dealer, so dont really want to waste time and fuel if it`s gonna be no good.
x 8126
Re: RH drivers window switch module 2008 207cc convertible
Since none of the numbers on the two plugs match up I would think that is the wrong one for your car. It maybe they use the same moulding for different vehicles but the connections may differ! :)
