x 2341
Unread post by MattBLancs »
MattBLancs wrote: 28 Jun 2025, 22:26 The answer is an odd failure (and an odd fix) - unhelpfully I've painted it with a bit of the grey primer too.
So the odd fix for an odd fault is as follows:
As long as we've had this car it's boot has shut with a bit of a rattle and bit of a clang.
The rattle seemingly, was this lot:
Rock hard lumps of seam sealer and a broken clip
These were floating about in the void between two layers of the boot structure.
The clang was these two "links" between outer and inner, seemingly bonded together with a black sealant. In service life of that is obviously long past as neither link was actually stuck to the other surface!
Black sealant (and pop rivets - explained below)
Black gunge also explained below
x 2341
Rp0thejester wrote: 29 Jun 2025, 20:59 Well when you say waffle you certainly mean it,
Oh, aye! I don't do nowt by halves! :rofl2:
but I'm more interested in how you got the brown lid to crack in the centre. There must be a story there as it doesn't look like a cut mark.
Odd isn't it! Sorry I don't know the back story as ...
As foretold by wise Homer
Has had the crack for more than 15 years bins older than our ownership of the house.
Two theories:
  • Poor molding plus thermal stress from the sun
    Or
  • Poor substitute for a step, not quite failing catastrophically but not happy being stood on!
x 1068
Unread post by Rp0thejester »
:rofl2: :rofl2:
x 2341
I worked out I could pop rivet the two struts in place and better yet that the rivet heads would sit behind the numberplate. So that's what I did!
Black gunge a bit of waterproofing, a bit of it's claimed "reduces drumming"
I bought some "matching" spray paint from Halfords, it's fair to say given reg number and then paint code inputted for it to come up with this choice and think it matches in terms of "grey" and "metallic" and that's about it!
Grey Thorium my arse!
:-D
x 1068
Oh wow, what a colour match, even a blind man could spot the difference
x 2341
Rp0thejester wrote: 29 Jun 2025, 22:13 Oh wow, what a colour match, even a blind man could spot the difference
Yes, pretty terrible! Nevermind. I've got two tins if this stuff in the way:
https://ebay.us/m/sGiJ0S
KTH GRIS THORIUM GREY FOR PEUGEOT AEROSOL SPRAY PAINT 400ML
Hopefully a good match.
Oh, and in my usual "not really a significant problem but I'll fix it anyway" approach, the rear numberplate lamps, which seem to shine light up inside the handle/trim as much as actually at the number plate! Now have stainless steel (ex cooker hood) reflectors to bounce the light back down again:
Before
Before
And after:
x 2341
Apologies for the knees, obviously
x 2341
Hot off the press, principally for your amusement, I have become a YouTuber
memberlist.php?mode=viewprofile&u=35281 Rp0thejester = opportunity to experience the waffling in an audio visual form, direct from the source! :-D
x 1068
Were they really that difficult to keep hold of? Or are you just clumsy? :-D A video like that might seem silly to us that 'know' but some will find that informative (yes, I'm thinking of people born after 1999).
x 2341
Rp0thejester wrote: 30 Jun 2025, 08:41 Were they really that difficult to keep hold of? Or are you just clumsy? :-D A video like that might seem silly to us that 'know' but some will find that informative (yes, I'm thinking of people born after 1999).
Clumsy oaf, yes.
Also "light misting" remember, it's p**s wet through with oil!
But mostly clumsy oaf...
x 3566
MattBLancs wrote: 30 Jun 2025, 07:14 Apologies for the knees, obviously
Are all three of them yours ? :-k
x 2341
bobins wrote: 30 Jun 2025, 16:10 Are all three of them yours ? :-k
I've had a thorough search and one seems to have gone missing - back down to two again. Must have been a trick of the light, fooled the camera and made it look like three!
Pretty sure it wasn't one of those AI errors :rofl2:
x 3566
Two is still more than the average number of knees ! :?
x 2341
"Engine Fault, Repair Needed"
Came back today. When I pulled into the car park about 10 minutes later the radiator cooling fan(s) were running. I wonder if it's to do with doing a regen that triggers it. It came on during a long downhill stretch of motorway - I know significant "over run" will interrupt a regen, but should not raise a fault this my knowledge!
Will see if I've time and enthusiasm to get on Diagbox tonight
x 8386
Reminds me Matt, I need to pop the Diagbox on mine to see when it last regenned. I try to give it an occasional run where it might have a regen chance.
Given its current usage patterns it will be good to see if it does actually manage to or if I need to kick one off using Diagbox...
