Normal current reading when asleep
Chefslot
x 14
Unread post by Chefslot »
Boxer 3 2.0 hdi
Been trying to detect a parasitic draw. I found what I believe it was on the 40A fuse in the engine compartment for the fuel heater. It was reading about 180mA before. Once I pulled the fuse the meter dropped by around 100mA. I was using a clamp meter so not the most accurate way.
The fuse is back in and now when taking a reading directly into the multimeter, I'm getting 45-50mA with the occasional bounce up. This has been asleep for a hour, is this an acceptable range? (Please see video)
Secondly, I'm trying to understand why. The battery had been removed before, so if it was a stuck relay it would have lost power before I removed the fuse right? The fuse didn't seem overly corroded, or did the unit need power when I removed the fuse to change the state of another relay, if that makes sense? It hasn't came back even after starting the engine.
Kind regards
Reason: Tags
x 1045
Re: Normal current reading when asleep
Unread post by wheeler »
I'd say anything up to 0.06A would be OK.
Chefslot
x 14
Thank you, the sudden increase, is this the alarm system?
x 1045
What does it bounce up to & how long does it last?
Chefslot
x 14
Bounces up to 156 ish for a second then back down sometimes quickly back up again every 1-2 minutes. Trying to work out if the previous owner has a tracker fitted and forgot to remove it when sold or if its the original alarm system. Removed all other aftermarket items like flashing lights and towbar equipment.
x 2943
If you have an aftermarket alarm they are, or used to be, the first thing to look at when batteries were going flat.
Chefslot
x 14
As far as I'm aware it's just the standard alarm system.
