Clutch Sensor Location
Gerry_123
May anyone advise the location of this switch ? It shows in diagbox both as binary 1/0 & an analogue % depressed ? I am asking as sometimes I have to repeat the clutch / de-clutch 3 times to get the car to start. Its a 2016 508 2.0 hdi. Thanks.
OnlineRichardW
- x 1456
Re: Clutch Sensor Location
As far as I know it's part of the master cylinder - failure of this on C4 Picassos (which is the same underneath) is pretty common.
Gerry_123
Thanks. Do you know if it may be replaced separate to to the master cylinder ?
