Suspension collapse and p1shin what I guess is hydraulic oil
boristhespie
x 4
Re: Suspension collapse and p1shin what I guess is hydraulic oil
Unread post by boristhespie »
I bought prior to your answer. Are these are Ok?
https://m.autodoc.co.uk/suplex/10190153
C'est pas possible!
MGmike
x 63
Unread post by MGmike »
boristhespie wrote: 22 May 2025, 15:44 I bought prior to your answer. Are these are Ok?
They'll fit but the pressure is nearer that used on the H3+ cars.
It'll be interesting to hear how the car rides when fitted as it may be a little firmer.
Kees
x 150
Unread post by Kees »
This one is for the center sphere, not the corner one's
And it's better to buy a IFHS, because of the quality
boristhespie
x 4
Centre sphere? I thought there were only 4. One each corner.
I went with these because they said for my model in. Description.
Where would I find IFHS? Can you provide a links thanks.
C'est pas possible!
Kees
x 150
You are right, this is why I commented on your post.
You need a sphere with 31 bar and a damper.
This other one is one with no damper.
Because I live in the Netherlands, I can't provide a dealer for you, but you can Google for yourself.
boristhespie
x 4
Seen these.
https://ebay.us/m/AmOf9S
I aint mechanically minded
C'est pas possible!
x 5675
boristhespie wrote: 23 May 2025, 09:09 Seen these.
something wrong there!
x 1943
I got that message as well. And then I tried again and it worked!
Kees
x 150
Be careful, because you can not see if this one's are the right one, I can't see what the pressure is, so you don't know if these are the right ones.
Kees
x 150
You have to look for IFHS C531CA
