Citroen DS3 2010 PETROL ESP FAULT
LONDYDS3
Unread post by LONDYDS3 »
Hi all
I am having problems with my Citroen ds3 ESP light is on. Taken it to peugeot/Citroen specialist ( not main dealer ) coming up with fault code C1136 steering wheel angle sensor signal fault coherence and no communication, changed comm unit ESP light still illuminated, been told to take it to main dealer but cant as there is such a backlog for appointments 6-8 weeks waiting time.
Does anybody have any suggestions on any garages that have live software updates using Diagbox?? (Midlands )
Ive seen a few posts on here with members list regarding ESP can anyone help at all. Would be much appreciated.
Huskyxantia
x 909
Re: Citroen DS3 2010 PETROL ESP FAULT
Unread post by Huskyxantia »
Try jacking the car up so both wheels are off the ground .
Start the car and with the engine running ,turn the wheel full lock both ways several times, switch off the car after making sure the steering wheel is center . Restart the car and see if the light goes off, it works after the front suspension has been worked on and things removed, good luck
:-D
