x 2231
Unread post by MattBLancs »
bobins wrote: 10 May 2025, 09:34 The name escapes me, Mick :lol:
mickthemaverick wrote: 10 May 2025, 09:35 Great!!!
Ha ha! Think we'll work it out between us eventually :rofl2:
Do you want another "boot full of more buckets of soil" picture or leave it to your imaginations? :P
Loaded up again just trying to work out when best to go (for minimum busyness!) was rammed 15 minutes after opening time this morning!
x 2231
The purple has arrived
Slide modifications to follow (plus, err, hard landscaping)
x 7966
Methinks the ladder should be lime green as a safety feature!! :-D
x 2231
mickthemaverick wrote: 10 May 2025, 14:33 Methinks the ladder should be lime green as a safety feature!! :-D
Have you got shares in Ronseal? :rofl2:
x 2231
Missed
Missed
x 7966
x 2231
Thanks for the link, but since we've "got the brush warmed up", Sarah's chosen to make the steps purple too.
x 2231
Blue 308 SW fill up:
514 miles, 134.7 PPL, £52.87. 39.25 litres = 8.6 gallons
Hence 59.5 mpg = happy with that, especially as quite a few short (tip) runs as a part of that!
Oh, and "Electrical system fault, gave vehicle repaired" has made a reappearance this morning. Diagbox session tonight (assuming it gets me home! :lol: )
x 2231
Obviously, as this particular trailer hasn't been used for a month or two, it's lights have reverted to their default state....
... A quick clean up and retightening it's mounting bolt (which is earth connection) has got tail light at this side to play ball. Indicator remains stubbornly reluctant). Other side well behaved.
Tomorrow, fresh enthusiasm should get it sorted and then on to builders' merchant for a quantity of sharp sand. (My dad is laying flags)
Neither verbal abuse nor rude gestures seem to have helped either
:-D
x 2231
Oil change and sump swap (in hope of sorting oil weep and modified stuff mo to give full draining) was this afternoon's plan.
Oil on way out. Discover I've no oil filter (have got a fuel filter though) then obviously the heavens opened!
Passing shower, hopefully!
x 2231
Break in the weather: sump off.
Quick drain of what's in the sump, this bottle is 250 ml so must be a good 200ml left behind at each oil change.
Fruit shoots bottle becomes oil estimation tank
Standard sump
Standard sump
Modified version:
x 8203
I'm hoping my new sump-sucker might do a better job of evacuating all the oil when I do my next oil change on m C3 Matt. The 'innie' sump plug design is a bit rubbish really - I'm guessing that for some reason they were aiming for a flat sump bottom. Maybe it allows the engine to 'sit' well on a pallet during manufacture?
x 2231
CitroJim wrote: 26 May 2025, 05:27 I'm hoping my new sump-sucker might do a better job of evacuating all the oil when I do my next oil change on m C3 Matt. The 'innie' sump plug design is a bit rubbish really - I'm guessing that for some reason they were aiming for a flat sump bottom. Maybe it allows the engine to 'sit' well on a pallet during manufacture?
Yes, interesting this could be better drained by the "short cut" suction method rather than the "proper" oil drain plug! Would be surprised if it's worse, put it that way!! :-D
Yes, think either to sit flat or perhaps to shield it from being ripped out in the case of "grounding out" ? Thin steel sump you are very close to disaster regardless id say!
x 2231
Another trip to the tip in the Blue 308, guessing everyone has had more than enough "boot full" pics for the moment :)
x 2231
Take one rusty/failing powder coat clothes airer,
Missed from the tip trip
Chop off a bit, bend
Plus deburred
Plus deburred
Just the ticket
Noticed the tensioner quite stiff, so removed to lubricate it.
Then noticed someone has been here before.
Spot the odd one out, even easier once removed!
Close enough!? Well, it is M8 so at least that's correct
Decided (having lubricated tensioner) to go for three matching M8 with 13mm heads (plus thin washers) and a spot of thread lock on each.
Strangely there's two tensioners on this belt, both sprung, one either side of the alternator. Guess something to do with the Start Stop (as think alternator may also restart the engine??) which would change where belt needed tension (after crank pulley or after alternator)
