2014 Peugeot 5008 boot not opening!
paddypaws77
Unread post by paddypaws77 »
Hi!
Any chance somone can give me wiring diagrams for the boot circuit for a 2014 Peugeot 5008?
For a while there has been a very intermittent problem with the boot not opening. It always righted itself so hard to get to the bottom of it. However, the boot has now stopped opening altogether and I need to have a look at it. I gather it is likely the wires broken where they pass into the boot from the car. It would be very useful to have a wiring diagram before I start delving in to it.
Many thanks!
Phil :-D
x 1056
Re: 2014 Peugeot 5008 boot not opening!
Unread post by wheeler »
Whats your VIN?
Ctonking
Unread post by Ctonking »
Hi, this has happened to mine. Can anyone help? If there at least a way to open it from inside?
x 1056
If you look at the catch from inside you should see a little hole here. Get a very small screwdriver & you should be able to flick the emergency release to open the bootlid.
It can be hard to see when its fitted on the car.
Ctonking
Thank you. I’ve had a go. I’m not sure if my screwdriver is too big but I’m not actually sure what I’m meant to do. Is it pressing down or turning something?
x 1056
Ctonking
Thank you so much for your help. It actually opened normally this morning but has since reverted back. I can feel the sort of click when pressing the button. I’m going to assume a wiring/button fault. How possible is that to fix yourself? Are there any guides on how to do it or where to buy parts from?
x 1056
First port of call especially if it’s intermittent is to check for broken wires in the sleeve between the body & tailgate. Common break point due to the flexing as you open and close the boot.
