Greetings all and a DS5 with non working air con
Old_and_Slack_900
Unread post by Old_and_Slack_900 »
First post so please go easy? Ta.
I have a 2015 DS1.6 diesel manual.
The air con stopped working so I’ve checked the usual stuff like the fuse (ok) changed the sensor for a new one and checked the charge pressure which shows as spot on.
When I switch the a/c on , there’s no ‘clunk’ of the compressor coming on.
I’m out of ideas.
What am I missing?
Cheers all
x 1953
Re: Greetings all and a DS5 with non working air con
You need to get the car read by a decent code reader, preferably Diagbox, to see what errors are stored in the ECUs. Without those it's just guessing in the dark, to mix a metaphor.
Old_and_Slack_900
Thanks. Thought as much 🙄😁
PaulC5
x 717
Unread post by PaulC5 »
Having enough pressure is not the same as having enough refrigerant, there is a chance it may still need a regas but see what the diagnostic shows.
