Maybe i dont know how to search but never found an answer.
PSA seems to have 2 types of piloted manual gearboxes in all the 2000-x cars - either 6 speed with hydraulic actuators (called EGS6 or ETG6 or BVMP6) fitted with 1.6HDI and bigger engines or 5 speed with electric motor operated actuators (BVMP5) fitted to 1.4HDI engines (something similar situation for gasolines too).
As i understood the EGS6 is the same gearbox from 2004 till.. 2018?
I used to own 2005 Citroen C4 1.6HDI with EGS6, it fees like you drive a manual and someone operates the clutch and gears for you (slowly..).
Recently i test drove a 2012 Peugeot 308 1.6HDI with the same gearbox (as i understood) - but the feelings are completely different - i would never say that its NOT a normal automatic - gears shift is very fast especially in sport mode (like in DSG
How is that possible? Different SW?
Now i have 2012 Peugeot 208 with 1.4HDI and BVMP5 and this is the worst gearbox i ever had.. gears shift is slow, sometimes it like declutches too fast and car kicks (usually when slowing down), sometimes revving as hell between shifts, sometimes when you slow down at a cross section around 10kmp (6mph?) it does not do anything for about 5 secs.. waiting for car speed to match to any gear, then revv as hell and engage the 1st gear.
And the final idea - fit an EGS6 to my car with 1.4HDI? (in addition should provide better fuel economy at high speeds with the 6th gear?)
But how to find a good EGS (like in 308) and not a slow one like in old C4?
