308 CC Dashboarb Connector plug from RCZ
maximgranovskiy
Unread post by maximgranovskiy »
Hey everyone.
Peugeot 308 CC 1.6 VTi 120 from 2010
I have several question, maybe someone can help me
I bot a Dashboard from RCZ with bigger display but now i need make a connection. What i know:
-New dashboard have a two plug connectors 'yellow Big end brown Smaller 6-pin
-My dashboard have only bigger Yellow connector
- I know that I need from brown connector 1-2-3-6 pins cables but in bigger yellow connector. Hier 1pin is power, 2-3pins is Can, 6pin is ground.
- 4pin end 5pin i need put to R Multifunktion regulator: ring,volume +-,mode. Steering Wheel
Now my questions
- I need the pins numbers of yellow adapter, names and colours of cables with i must to work
- I have no ideas where is a plug for Steering Wheel, and also numbers and names of pins
I found it. But in not sure end i have no idea where is a 84B3 cables
Reason: Image tags
Fab70ar
New User
Re: 308 CC Dashboarb Connector plug from RCZ
Unread post by Fab70ar »
HI, i am in the same situation, i have a dashboard from 308 RCZ and i want to conect the small 6 pins connector.
have you done it?
any help will be appreciated.
thanks!
