Citroen xsara picasso
Ian o
Unread post by Ian o »
Just replaced heater blower electrical connection block as it had burnt connectors and stopped working, all wired up but now blower on constantly.
Any ideas why?
xsara92
x 3
Re: Citroen xsara picasso
Unread post by xsara92 »
Does your car have manual or automatic temperature reg?
If it's the manual panel with the dials, the fan control variable resistor itself often fails.
Ian o
It's electronic screen display with button you press to get it to the setting you want have got power going down one cable all the time engine is running and blower on full blast
xsara92
x 3
That's annoying Ian, I don't think my Haynes manual for the Xsara Pic has specific info about the automatic module but I will check and pass on anything in there
Ian o
My Haynes manual does not cover it, only the old style manual knob
PaulC5
x 665
Unread post by PaulC5 »
Could be a failed resistor pack. As an aside, have you been keeping up to date replacing the cabin filter, a long time ago I read that the ignition switches can burn out if the filter is not replaced.
Ian o
Replaced resistor a couple of years ago, to be fair not sure when I Replaced cabin filter but probably last year when I serviced it.
It's my daughters car and I don't keep a record of what I have done and when just glad to give it back 🤣 I am a volvo man and I hate her car but I do want I can to help her.
