Bosch VE Fuel Pump Timing-Headache
Jasonrelli
Unread post by Jasonrelli »
Hi,after having a big fuel pump leak,i locked my pump pulley,unbolted and removed the pump and had it serviced,pump is now fine,however,it dosen't have a woodruff key,its just a tapered end and foolishly i didn't make any necessary markings,can i put the pump in and re-time it with the engine set to TDC or am i screwed?,i'm out of my depth,do i now have to send the pump away again to be timed?,and must i include the pulley and flange as well,so would then have to remove the timing belt,what a pickle i'm in..
Advice anyone please?
Car is a Peugeot expert diesal 1996
x 1489
Re: Bosch VE Fuel Pump Timing-Headache
The pump is only timed by its position relative to the crankshaft. However, you do need to know that it is on the right firing stroke. There must a timing mark on the pump somewhere so that you know you have the right cylinder in reference, but I don't know what... There's a Haynes manual specific to the XUD engine which no doubt explains it.
x 1053
Unread post by wheeler »
Is this an XUD engine? Turbo or non turbo?
Surely there has to be some sort of woodruff key?
Jasonrelli
Hi,thanks for replys,It's a XUD engine,peugeot expert 1.9,non turbo,my silly mistake,the key fell out somewhere when removing the pump,i guess if i can buy one,you slot it back in,then manually turn pump to approx position,of the keyhole on the flange which i locked when bolting the spindle,slot pump back in again,attach all fuel lines,and then fine tuning if required,is by setting engine to TDC and using a reader plugged in the other end of pump,not experienced with that,but hopefully it might start and i could drive to a garage...
x 8397
Hi Jason, the key is only needed for location/timing purposes and does not transmit drive - that's all done by the taper and a tight nut!
I'd simply make up a substitute key - it can even be a bit of plastic if you don't feel like bashing metal.... Then reassemble...
I know and feel your pain about how the key likes to make a bid for freedom I've always stuffed loads of rags around the area to catch the errant key
Do have a good look for the lost key - the very last thing you want is for it to get tangled up in the cam belt - it will end in tears if it does. I've seen the aftermath :(
