- x 5670
Or hang your coat on.
- x 8343
- x 1998
Pond in the field I look over has its yearly duck....first swim for the young-uns
- x 8343
That is truly magical Alasdair
The perfect harbinger of spring
- x 8083
- x 3566
Ideal for very efficient growing of mustard and cress, obviously
I love their spelling of 'substrate'
- x 8083
I missed that when I read it, certainly is a cracker, I was going for mint!!bobins wrote: 28 Mar 2025, 13:14 Ideal for very efficient growing of mustard and cress, obviously![]()
I love their spelling of 'substrate'![]()
- x 8343
Never heard it called that before
Last thing you ever want is a crooked sub
- x 2941
I wonder if it's a sneaky advert by the cops to see who's buying.
- x 8343
Gibbo2286 wrote: 28 Mar 2025, 14:03 I wonder if it's a sneaky advert by the cops to see who's buying.
If not, it would be a good ploy to adopt...
- x 8343
A tulip in full bloom in my garden
They've bloomed before the daffodils... I have other tulips that are yet even to bud... These are incredibly early...
I do like the juxtaposition of the snail shell and leaf...
- x 8343
Something a little different today...
I finally got your negative scanner fired up James
This is what it did with one of my home-processed negs
Not bad for its 5MP resolution
I'm rather pleased. Thanks hugely for the loan of the scanner James
The bridge in the photo connects our parish church with the cemetery. It is notorious for being struck by Luton box-vans. Hence the sign...
The processed film did show up a problem with the shutter in my £10 Charity Shop find Canon EOS 500. It was found to be suffering contamination due to disintegrating foam shutter 'bumpers' and causing it to be a bit sticky and intermittent in operation. A common problem now on lots of cameras over a certain age it seems...
Now fixed (fingers-crossed) by cleaning the shutter leaves with huge care using naphtha (lighter fuel), strips of card and cotton buds...
I've found Reddit has a brilliant subreddit dealing with analogue (film) camera repairs
- x 3302
I am glad it is of use, Jim. You can borrow it for as long as you need it, but I will let you know if I spot them on Aldi/Lidl website. The bit I couldn't get to grips with (due to lack of knowledge/experience) is adjusting the colour balance for 'distorted' images.
- x 8343
Hell Razor5543 wrote: 31 Mar 2025, 17:30 I am glad it is of use, Jim. You can borrow it for as long as you need it, but I will let you know if I spot them on Aldi/Lidl website. The bit I couldn't get to grips with (due to lack of knowledge/experience) is adjusting the colour balance for 'distorted' images.
Thanks James
I've got to grips with it very well. No problems using the colour balance settings and I found if I did need to do any post processing I could import the scan into the GIMP and work on it from there... The image above is straight out of your scanner with no adjustments or post-processing
I've just sent you a PM about it
- x 8083
This is the one I've got Jim which works very well I think!!
https://www.amazon.co.uk/Mini-Digital-F ... 1_6?sr=8-6
An example image from a 60 year old negative found in a bin:
