Xantia - Rear wheel alignment / \
fastandfurryous
- x 4
fastandfurryous
- x 4
Mkalic
- x 3
Re: Xantia - Rear wheel alignment / \
I know it's a really old thread, but if this bearing is the problem, can you feel the play if you lift the car up, or is it the same as in the Xsara, where it wasn't possible.
- x 1449
Probably if you depressure the suspension. Usually they give themselves away by being noisy, or the tyres developing in inward lean at the top.
wurlycorner
- x 272
With suspension depressurised and car jacked up, it is possible to detect yes.Mkalic wrote: 24 Mar 2025, 15:29 I know it's a really old thread, but if this bearing is the problem, can you feel the play if you lift the car up, or is it the same as in the Xsara, where it wasn't possible.
Iain
CX DTR T2 Safari (silver)
Iain
