C6 HOW TO replace front suspension unit
citroenroen
Unread post by citroenroen »
what are steps to remove my failed front suspension unit on 2006 C6 ?
1 . How do I depressurize suspension ? (prior to removal ?)
2. at what point / when do I remove suspension sphere ?
3. when do I remove 3 allen headed bolts on top ?
4. is removal through bottom?
5. any other pieces that need to be removed / detached in order to facilitate suspension unit removal ?
6. I have been unable to find new line seals ? Can I reuse old seals ? Or does someone have new seals available ?
Thank you
cit-rotti
x 77
Re: C6 HOW TO replace front suspension unit
Unread post by cit-rotti »
citroenroen wrote: 22 Mar 2025, 16:59 what are steps to remove my failed front suspension unit on 2006 C6 ?
Thank you
There is an excellent forum for the C6
https://c6owners.org/C6_Error_Codes.php
All original technical documents can be downloaded there, provided the conditions are met.
