Just to prove S**t really does happen!!
- x 1072
Re: Just to prove S**t really does happen!!
You missed an opportunity there, if you threw swmbo in the sewage would you get a replacement? Just asking for a friend.....
Champion of Where's CitroJim
- x 8397
That's good Mick
Pleased to see it's been more or less resolved
- x 8123
Another quick update, in addition to the cement repair and painting, I have just bought 80 x 50cm square carpet tiles for £20 which I collect later today. Negotiations have been going on as I watch qualifying!!
- x 8397
Do you really need to be qualified to lay carpet tiles Mick?
- x 8123
Only if you're a hen!!
- x 8397
mickthemaverick wrote: 15 Mar 2025, 06:14Only if you're a hen!!![]()
- x 8123
First tip run under way. Got here 9.30 opens at 10, used to be 9!! Still using SWMBO'S car so all precautions taken!
- x 8123
I have now completed the tip runs with this being the last load:
The steel plate is now laying over the manhole purely to better support the carpet tiles which I am collecting in a couple of hours!!
Hopefully it will be dry tomorrow so I can get on with prepping the floor although the cement won't be here until Monday.
- x 5672
Painting floors is easier with a roller on a broomshaft.
Just pour the paint out and spread it around.
- x 8123
If I had a suitable roller I probably would Steve but I buried all my painting kit at the back of the tent so cheaper to buy the brushes than a decent size roller. I probably will strap the 3" one to a pole
- x 1996
Window Squeegee, it spreads it well ........ then use your brushes.
- x 8123
I like that Alasdair thanks, I have one on a 2m extendable pole too so that's my best option so far. I have to repair some concrete damage first but hopefully painting could be on the cards by Tuesday!!
Ever since I ran my garage business I've been getting catalogues from this company.
https://polycote.com/
- x 8123
Thanks Gibbo, that looks like a decent range but far too good for my garage. I will be 'floating postfix' over the rough concrete simply to flatten it, then painting with Johnson's Floor Paint which I have in stock and finally laying the superb carpet tiles I collected yesterday which I am exceptionally pleased with. Watch this space!!
- x 2341
Instead of postfix, worth getting proper self leveling compound instead Mick?
It's not super expensive from memory, I put some down on our kitchen floor
