Car completely dead
Chicken little
Car completely dead
Unread post by Chicken little »
We have a 3008 which started displaying bpga issues, Bpga replaced end of last year, then randomly the car is completely dead, no response from stop start button, literally nothing. It's like it's completely shut down, battery is fine (replaced November) and also reading good voltage. Scanned and bringing up multiple faults but because the ignition won't turn on they are stuck finding what is causing the issue. Bpga replaced again in case it was a faulty one, car started for a split second and blew the relay. Continuity tests all good so shouldn't be a broken wire, fuses all good. Garage is at a complete loss, unless we start guessing if its a random bcm and replacing and coding not sure what else to do, it's like chasing a ghost.....
x 1053
Re: Car completely dead
Unread post by wheeler »
When you say completely dead do you mean nothing at all? Do the hazard lights switch on if you press the hazard switch?
Have the main power supplies & earths been checked & confirmed good?
Have all fuses been checked including the maxi fuses?
Chicken little
The door unlocks and the light flashes on wing mirrors but don't open, when you press the stop start to get the dash to light up absolutely nothing, parking break is stuck on, steering wheel is locked, economy mode lights up ( only because its been stood) but when they put the jump pack on the battery it reads correctly but because the ignition won't turn on the scanner cannot complete the scan. Absolutely no response from thestop/start ignition.
Chicken little
All fuses checked, continuity test shows no breaks in any wiring
Arkis
x 27
Unread post by Arkis »
Have you tried disconnecting the battery for an hour? Doing BSI reset? Does 3008 have main fuses at the battery (little plastic box in front of or on top of battery)? Did you check those?
Edit: Yeah, BPGA is that "fuse box" I was reffering to.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
