Dave J65
Unread post by Dave J65 »
GiveMeABreak wrote: 09 Mar 2025, 09:58
Dave J65 wrote: 08 Mar 2025, 17:36 Marc,
Thanks for this, unfortunately I meant inner wheel arch, not wing.
Apologies.
Dave
The only other parts showing:
Left ArchRight Arch
(10) Front Wheel Arch
Right, part: 7120G2, £144.62
Left, part: 7119E1, £168.73
On my previous post diagram below, item (6) is the Front Wing Mudflap Frame:
Left, part: 7136FK, £50.81
Right, part: 7136FL, £53.11
GiveMeABreak wrote: 08 Mar 2025, 14:20 Image
Thanks Marc, I appreciate your time spent on my request.
pcb007
Unread post by pcb007 »
Is it possible to get a part number please for heater resistor for c4 grand picasso picasso 2016 with
vin VF7**************[VIN obfuscated, can be read by forum staff]
Modami
Unread post by Modami »
Hi Marc,
According to the schematics number 1.)
It will be number 15 and 7. Most likely number 6 as well.
From fasteners - the ones used to mount above, but I see 6997T2 you already mentioned. Also door card clips and this type
bottom trunk lid
bottom trunk lid
Cheers.
Markyt1980
Unread post by Markyt1980 »
GiveMeABreak wrote: 08 Mar 2025, 12:38 So as I said I can't comment on after-market sellers, but they are listing that as a compatible part (4541QE), so you would have to take them at their word. But you may still need to have the configuration checked if the vehicle has a different equipment to your vehicle and it will definitely need to have the steering wheel angle sensor calibrated too.
Thank you for that info. Well I contacted them to double check and it turns out that they have lumped them together and it’s actually a 4541 JH. I am at a loss. I do t understand why there are so many part numbers. :( I desperately need to find a replacement here so I can drive back to Greece with the car safely. I need to be back here in the uk by April to get my uk astra fixed (clutch went the other day) All I am seeing is so many numbers beginning with 9 for part numbers. And I’m dammed if I can afford to spend £1700 on a part for a car that’s registered in 2007. It’s a nightmare I just can’t afford that and it’s frustrating when I can see so many parts online second hand for so
Much less. What are these other part numbers that all begin with 9. Are they after market numbers? Sorry to ask all these questions. I’m just really stressed as I am meant to be driving back with the car from Thursday.
x 6957
4541JH is not listed as a current or previous part for your vehicle.
4541AF was the original part number (to be configured)
4541QE is the replacement part (to be configured)
4541AG was the Pre-configured part based on the vehicle's options
Either way you can't just replace it without configuring it for the correct vehicle and undertaking the steering wheel angle calibration otherwise it will be going mad beeping at you all the time and all ESP functions will be disabled.
x 6957
pcb007 wrote: 10 Mar 2025, 11:57 Is it possible to get a part number please for heater resistor for c4 grand picasso picasso 2016 with
Your VIN is incorrect. It should be 17 long not 16
x 6957
Modami wrote: 10 Mar 2025, 12:18 Hi Marc,
Cheers.
(6) Bulkhead Soundproofing, part: 7481CP, £58.18
(7) Bulkhead Soundproofing (Left), part: 7481CS, £113.94
(15) Bulkhead Soundproofing (Right), part: 7481CR, £92.18
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
MOT Failure on the green S1 today!
Nearside front CV gaiter
Nearside front indicator unit.
Please may I have the relevant part numbers?
Also the rev counter has stopped working. I haven't tried the fix as suggested in one post I have just read but please could I also have the part number for the sensor which sits on the differential?
TIA
Old Berlingo
Unread post by Old Berlingo »
Hi Marc / Richard,
I’m after the original part numbers for the front bumper, bumper mounts and the cowling that goes under the front of the car please.
My car details are:
2001 Citroen Berlingo 1.4i petrol
Engine No.: FS873499453
Thank you so much
x 1488
pcb007 wrote: 10 Mar 2025, 11:57 Is it possible to get a part number please for heater resistor for c4 grand picasso 2016 with
Item 3 - 9821291880 - £194.08 Don't but a cheap one off ebay, they mostly don't work!
x 1488
Rhothgar wrote: 10 Mar 2025, 16:47 MOT Failure on the green S1 today!
TIA
Can you post the VIN, I'm not as organised as Marc....!
pcb007
Thanks for that and I've found out already they don't work
x 1488
Old Berlingo wrote: 11 Mar 2025, 12:22 Hi Marc / Richard,
My car details are:
Thank you so much
Bumper was 7401H7, but unsurprisingly NFP! If you want more parts than are shown on the that drawing let me know.
I can't see an obvious undertray, it may not have had one originally.
Old Berlingo
Hi Richard,
NFP seems to be my new best friend :rofl2:
Regarding the undertray, it’s made of a flexible rubber similar to lay flat floor vinyl. I’ve still got my original so I might try and do some magic with it. I’ve had the car since new and it definitely came with that. Perhaps it was fitted to Australian Berlingos to comply with some local law at the time, who knows?
Anyway, thank you so much for your help
abyj
Unread post by abyj »
Could you please help me with the part number for the BSM and air con compressor clutch for my C3 A51 - VIN VF7**************[VIN obfuscated, can be read by forum staff]. Numbers on the BSM and compressor assembly are 9667199580 and 9670318880, although I'm not sure if they've been superseded. Hoping there is a separate part number for the clutch.
