BX Pressure regulator
alab
Unread post by alab »
Does anyone know if you can get a rebuild kit for the pressure regulator? If so, where from?
Thanks, Alastair[:)]
Dave Burns
Unread post by Dave Burns »
You might have some difficulty actualy getting into it, the end cap has to be pushed in against heavy spring pressure, this moves its tapered edge away from the retaining internal circlip.
But this circlip is the plain type with no lugs to get hold of, so the operation is very difficult, thus you may cause more harm than good.
Might be a good idea to restrict yourself to cleaning the non return ball valve if it looks grotty, its revealed when the sphere is removed.
Dave
