x 8134
Why would you want to put it in Matt, Jim? :-D
x 2356
Unread post by MattBLancs »
mickthemaverick wrote: 08 Mar 2025, 15:20 Is that a shim plate that should be between the pad and the caliper? :)
Yep, who knows why it's been shoved half way down the piston!? :)
x 2356
Just a matter of unscrewing the bottom ball joint next. Note use of high level left leg to help to stop the massive heavy steel workbench from turning over!
x 2356
New and old for comparison. Febi Bilstein (Autodoc from memory)
x 2356
New ball joint in place with copper grease. Hub flange cleaned up with flap disk
x 8415
mickthemaverick wrote: 08 Mar 2025, 15:21 Why would you want to put it in Matt, Jim? :-D
:lol: :lol: Shows how important punctuation is :wink: I blame it on the AdBlue I accidentally consumed yesterday :twisted:
Matt, You're doing some cracking work today 8-) :-D Weather is ideal for it!
x 2356
Thought he was encouraging me to drink it! :-D
x 2356
The gearbox underside is very oily but I don't think this seal is that fault. Drive shaft is very much lacking in oil coating which I thought it would do well to escape if this was the culprit
x 8415
MattBLancs wrote: 08 Mar 2025, 15:47
Gosh no Matt! I once ended up in A&E after a mishap with brake fluid...
MattBLancs wrote: 08 Mar 2025, 15:49
It may well be, it takes only a tiny leak to make a right mess! I tend to find little leaks don't get as far as the CV joint and if it does it may well get flung off before it can make a mess.
If you have one in stock, I'd be tempted to swap the seal for a new one whilst it's all in bits... Diff seals are one thing I always keep in stock...
x 8134
I have to agree with Jim there, whenever I expose a seal anywhere I always renew it as a matter of course, can save a lot of redoing jobs for the sake of a few quid!! :-D
x 2356
I do not have this one in stock (or I don't think so!)
Otherwise I'm same view as you both, get it changed. Next time I'm in the area will look to change it.
I was pretty convinced it's the engine sump gasket (or rather rtv at this joint) that's failed, but surprised how much is all over the gearbox and little on and around the sump.
May even be coming from engine further up - do DV6 oil filter housings have seals that fail? Half remember reading something about them?
Hoping it's not the turbo's oil feed as it's DPF off to get at that if so!
x 8415
MattBLancs wrote: 08 Mar 2025, 16:22do DV6 oil filter housings have seals that fail? Half remember reading something about them?
Yes, I have a feeling it was Husky who had one leak...
x 2356
CitroJim wrote: 08 Mar 2025, 17:02
Ah, ok I'll have a search on the forum.
Spot the brake fluid reservoir cap!
Took me 5 minutes to find where it had dropped to!
Another view:
It's visible in both images above!
Spoiler: show
go on, keep looking!
Spoiler: show
Oh all right then
Spoiler: show
Here it is!
Here it is!
x 8415
MattBLancs wrote: 08 Mar 2025, 17:07 Spot the brake fluid reservoir cap!
Spotted ;) A bit of zooming needed...
That did a good job of playing hide'n'seek :)
x 2356
Quick Autodoc search, oil cooler seals set (6 different ones seemingly)
https://m.autodoc.co.uk/3rg/10254267
£3.40
Will double check numbers on the Parts thread in a bit :)
Some other seals
https://m.autodoc.co.uk/ajusa/8554885
£1.51
And
https://m.autodoc.co.uk/ajusa/8554882
£2.41
Not sure if the above two form part of the 6 part set in the first link
