wurlycorner
x 272
Unread post by wurlycorner »
RichardW wrote: 02 Mar 2025, 22:08 Here's the diagram, lots of parts! I've marked the ones that look like the flexibles (only 2 are stated as such)
Thank you Richard.
Agree, looks like you've picked the right bits and ouch at some of the prices (definitely not a 'while you're in there' situation... I need to confirm specifically which ones!)
Iain
CX DTR T2 Safari (silver)
Jay-Bruce
x 282
Unread post by Jay-Bruce »
afternoon Marc, when you get a minute, can you give me some info on the resitor / module for the heater blower motor on my 407 coupe?
Micko
Unread post by Micko »
Can i get the numbers for all the engine Mount and gearbox Mount
BVL
Unread post by BVL »
Good morning Richard, Marc
Its time for me to solve my leaking camshaft housing of my 2015 1.6 blue hdi 120 because the oil leak gets worse.
could you give me the part numbers i need for the job as in:
camshaft oil seal, camshaft cover and packing , bolts to reassemble the camshaft housing , bolt for camshaft timing pulley , camshaft cover seal. ? and please the rubbers that suspend the airfilter housing front and back.
think that should cover the job, and any advice on the sealant to use for the camshaft housing ?
Any other parts i should take in consideration to replace from your experience ?
Thanks,
Bart
x 1900
Before you dive in to the job, are you sure it's the camshaft seal leaking? I've just had the job done on our 308 (same spec as yours) and it was only the cam cover tat was leaking. If the cam oil seal is leaking then the oil will be going down the back of the timing belt. The cam cover leak results in oil pooling around the fuel injectors.
Apologies for the off-topic post but I felt it was important.
Dave J65
Unread post by Dave J65 »
Looking for N/S & O/S front inner wing repair panels if there's such a thing.
VIN; VF3**************[VIN obfuscated, can be read by forum staff]
BVL
Paul-R wrote: 05 Mar 2025, 09:32 Before you dive in to the job, are you sure it's the camshaft seal leaking? I've just had the job done on our 308 (same spec as yours) and it was only the cam cover tat was leaking. If the cam oil seal is leaking then the oil will be going down the back of the timing belt. The cam cover leak results in oil pooling around the fuel injectors.
Hi paul,
I have oil pooling aroud the injectors yes, its hard to say if it is the sealant from the cam sandwich or the camcover seal leaking.
just going to order all the parts in case it's the sealant packing leaking. but if i have to split the cam housing going to replace the oil seal as well.
going to be a combiantion job with my distribution belt as it's on for 10years now @ 170000 km.
x 6960
Jay-Bruce wrote: 04 Mar 2025, 14:29 afternoon Marc, when you get a minute, can you give me some info on the resitor / module for the heater blower motor on my 407 coupe?
Hi Jay, from the looks of it, there is no separate Heater Control Blower Motor listed, so is likely combined with the Air Blower itself as you can see - like the ones on the Xsara Picasso and some other vehicles of this year:
The whole unit (1) is no longer available from Peugeot, but was part: 6441S3
x 6960
Micko wrote: 04 Mar 2025, 17:07 Can i get the numbers for all the engine Mount and gearbox Mount
(1) ANTI-TORQUE LINK (RIGHT), part: 9804890680, £183.28
(5) ENGINE SUSPENSION TIE ROD, part: 9675636380, £11.40
(8) ENGINE FLEXIBLE MOUNTING (LEFT) INTM: 9673773380, £43.21
(10) ENGINE FLEXIBLE MOUNTING) (LEFT), part: 9673768680, £183.23
(13) ANTI-TORQUE LINK (RIGHT) SUP, Part: 9816338580, £79.25
(14) ENGINE FLEXIBLE MOUNTING (RIGHT) SUP, part: 9816339580, £184.49
(16) ENGINE MOUNTING BRACKET (RIGHT) INF, part: 9810141980, £149.18
(18) ENGINE FLEXIBLE MOUNTING, part: 9676416780, £15.14
(22) ENGINE MOUNTING BRACKET (RIGHT) INTM, part: 9805300680, £149.18
x 6960
BVL wrote: 05 Mar 2025, 08:12 Good morning Richard, Marc
Thanks,
Bart
You'll need to click these to zoom them:
Cylinder Head
Camshaft Belt Gear
Air Filter
x 6960
Dave J65 wrote: 05 Mar 2025, 12:19 Looking for N/S & O/S front inner wing repair panels if there's such a thing.
Your VIN is (18) too long, should be 17 - please correct.
French Divas
Unread post by French Divas »
Hi Marc,
I'm not sure how this part is called. I'm looking for the strip which "seals" the window to prevent water from entering the door. Left and right rear doors.
Thanks,
Bart
x 6960
French Divas wrote: 06 Mar 2025, 16:57 Hi Marc,
Thanks,
Bart
Please see the info below regarding the very important Takarta Airbag Recall which affects your vehicle being flagged up: I suggest you contact your nearest Citroen dealer with this reference and they will advise you when they can be replaced.
Airbag Takata - Information
Ref: NT7
Launch Date: 24/02/2025
Dear Customer, We confirm that your vehicle is equipped with Takata airbags, but it is not included in any measure already launched. We will provide further information as soon as it is time to proceed with the recall process for your vehicle. The Takata airbags recall is being implemented according to a staggered approach, to ensure safety first and service of all customers in the fastest and most efficient way: oldest vehicles are planned to be serviced first. We will send a dedicated safety notice for your vehicle in due time, providing all instructions needed. While we are operating a continuous monitoring of the behavior of Takata airbags, you are also invited to verify again on this webpage, to retrieve the most recent information in the fastest way.
(10) Rear Door Weatherstrip:
Left, part: 9687392480, £83.14
Right, part: 9687392080, £83.14
There are other seals for the window sill area if not the above, so let me know if other.
BVL
Hi ,
I am also looking for the parts number of the bolts to put the camshaft sandwich together ? the 8 bolts that tighten the shaft between the housing.
Cheers,
Bart
x 6960
I don't know which one's you mean - they should all be in the diagrams listed?
