x 6947
Huskyxantia wrote: 26 Feb 2025, 08:27 Hi Marc, could i have part number for crankshaft oil seal my vin
VF3**************[VIN obfuscated, can be read by forum staff] many thanks,
There are 2:
(5) Crankshaft Seal, part: 1608940680, £48.49
(6) Crankshaft Seal, part: 012749, £35.82
x 6947
completediv wrote: 26 Feb 2025, 10:13 Hi
Can you supply me with Part Number for Citroen C5 X7 Tourer 2010 Front Lower Suspension Arm Lower Hub Carrier Bush so I can source correct one on Ebay?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance
(1) Front Stub Axle Carrier
Left, part: 1640790280, £468.06
Right, part: 1640790480, £501.54
(4) Front Bearing Assembly
OEM Original, part: 335082 , £145.76
Citroen Cheaper Version, part: 1681930280, £54.91
If anything other, let me have the item number.
x 6947
GavinPJ wrote: 26 Feb 2025, 10:11 Morning lads,
Can I get the diagrams for any seals in or around the crankshaft (flywheel end) and any around
the flywheel or block etc. Want to see what is there before I pull it apart.
Thanks,
Gav.
GavinPJ
Unread post by GavinPJ »
GiveMeABreak wrote: 26 Feb 2025, 14:28
Thanks,
Gav.
VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Cheers Marc.
GavinPJ
Heater only working on number 4 setting on VF7**************[VIN obfuscated, can be read by forum staff]
Can I get the part number for the heater resister/rheostat.
Cheers.
Gav.
x 6947
Note, there's an urgent recall on this vehicle requiring the Takata Airbag Replacement, dated Jan 2025 - still outstanding, so don't hang about and get it booked in at the dealer - free of charge.
NQ3 - Takata Airbag Replacement
Please contact your Authorised Repairer to book an appointment
(4) Heater Motor Control Module, Part: 6441CT, £90.59
x 6947
Sorry Gav :oops: , a paste issue on my behalf - it is indeed, 6441 CT!
I'll correct this above and delete the superfluous posts now.
Starfish8828
Unread post by Starfish8828 »
Hi looking for build sheet for vin VF7**************[VIN obfuscated, can be read by forum staff]...New member. Thanks
GavinPJ
GiveMeABreak wrote: 26 Feb 2025, 16:03 Sorry Gav :oops: , a paste issue on my behalf - it is indeed, 6441 CT!
No problem at all and thanks for letting me know about the recall too.
Huskyxantia
x 926
Unread post by Huskyxantia »
RichardW wrote: 26 Feb 2025, 09:35 Front or rear?
Front , just behind the pully
:-D
bitsas004
ML6C gearbox drain plug part number
Unread post by bitsas004 »
I have Citroen Dispatch 2014 2.0hdi cant find gearbox drain plug anywhere. Mine is rounded off so need to replace. I know its magnetic too. Appreciate if anyone can tell me part number
x 6947
Re: ML6C gearbox drain plug part number
bitsas004 wrote: 26 Feb 2025, 20:38 I have Citroen Dispatch 2014 2.0hdi cant find gearbox drain plug anywhere. Mine is rounded off so need to replace. I know its magnetic too. Appreciate if anyone can tell me part number
Please post all part requests in the official Parts Forum Bitas2004.
Here if this is what you're after:
(12) Plug Seal, part: 031339
(15) Oil Drain Plug, 22111
Shown as (7) Here, torque to 3 daNm
x 6947
Starfish8828 wrote: 26 Feb 2025, 16:06 Hi looking for build sheet for vin VF7**************[VIN obfuscated, can be read by forum staff]...New member. Thanks
Hi, no problem, here you go:
Vehicle Characteristics
Vehicle familyC5 (X7)
AS/RP N°13177 CJ 1 0043
Warranty Start Date15/02/2013
Engine serial number10 DYZA 4029234
BERe2*2001/116*0360*25
P4A9666536199
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC5 (X7)
SILHOUETTE5 DOOR ESTATE
TRIM LEVELUPPER LOW PLUS
ENGINEDIESEL TURBO DW10BTED4 FAP
TRANSMISSIONBVM6
PAINT TYPEMETALLIC PAINTWORK
BODY COLOUREEH - HARIA2 GREY PAINT
INTERIOR TRIM TYPEANDORRA BRAID F771+LEATHER L019
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)BVM ML6 CL
DEFINITION TO FOLLOWRANGE ACTIVITY
ENGINE (TYPE)EW/DW
OTHER BADGE, " MISC. "EXCLUSIVE
BADGEC5
STEERINGUNVARIABLE POWER STEERING
SPEEDOMETER DRIVEW/O TACHO TORQUE
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 5 L6 UPPER ENGINE EMISSION CONTROL
EXHAUSTLONGITUDINAL REAR SILENCER
ENGINE (TYPE)EW/DW
CAPACITY2000 CM3
CATALYTIC CONVERTERCATALYTIC CONVERTER LESS THAN 10PPM
OIL COOLERMNTG WATER/OIL EXCHANGER ON ENGINE
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONNORMAL FUEL CONSUMPTION OPTIMISATION
COOLING MOTORRADIATOR THICKNESS: 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)POWER 100 KW 320 NM
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION)"EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTIONTECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 DUAL-SPEED ELECTRONIC FAN 140W
INJECTION ASSOCIATED VARIANTMOUNTING DELPHI
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM6
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 16 X 69
WHEEL STYLEIONIENNE2 "17-INCH" STYLE WHEEL
CLUTCHHYDRAULIC CLUTCH
SEAL, WHEEL ENDSEAL WHEEL SIDE AC 3300I
SEAL, DIFFERENTIAL ENDJOINT COTE PONT AAR 3300A
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 86
RIM/TYRE SIZE17 INCH TYRE FITMENT
TYRE (SIZE, TYPE)TYRE 225/55 R17 97W NON-REINFORCED
DRIVING WHEELS2 DRIVEN WHEELS
WHEEL (TYPE)IONNIENNE 17" ALLOY WHEEL RIM
INFLATION PRESSURE LOSS INDICATORTYRE DEFLECTION INDICATOR
GEARBOX TYPEML6C
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR DIAM 21
STEERING COLUMNMANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BARFRONT ANTI ROLL BAR DIAM 24,5
STEERING TRAVEL180 STEERING MECHANISM TRAVEL
SUSPENSIONNORMAL SUSPENSION
ACTIVE SUSPENSIONACTIVE SUSPENSION MANUAL ADJUSTMENT
SUSPENSION (ARCHITECTURE TYPE)HYDRAULIC SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)ASSISTED ELECTROHYDRAULIC STEERING
Body Fittings
TOWBARTOWBAR
PAYLOADNORMAL PAYLOAD
SIDE MOULDINGS (TYPE)CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION)PLASTIC + CHROME SIDE PROTECTORS
EXHAUST TAILPIPENON CHROME PLATED EXHAUST TAIL PIPE
INDICATORSLUMINOUS SIGNATURE
SILL ILLUMINATION LAMPSILL LIGHT FRONT AND REAR
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR ELECTRIC-FOLD BACK
WINDSCREEN WIPERFRONT WIPER AUTO SPEED 16 SPEED
REAR SCREEN WIPERWITH REAR WIPER
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
REAR TAILGATE GLASSFIXED TAILGATE WINDOW
BUMPERBODY COL BUMPER + CHROME PROT + CHROME GRILLE TRIM
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPFRONT FOG LIGHTS
SPARE WHEELSTEEL WHEEL + STANDARD TYRE
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE)TINTED EXT REAR VIEW MIRROR
EXTERIOR ACCESSORIESCHROME EFFECT EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
SUN ROOFFIXED ROOF
BUMPER TRIMBODY COLOUR BUMPER STRIP
GLASS (APPEARANCE)DEEP TINTED WINDOW
WINDOW (TYPE)ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
HANDS FREE ACCESS AND STARTINGWITHOUT HANDS-FREE ACCESS/STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR SEATSEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
GEAR SELECTORFLOOR GEAR CONTROL
DRIVING POSITIONLEFT-HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
BOOT AND LOAD SPACE LIGHTINGBOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENTLUCIANO METAL DECOR
MISC. INT. LAMPSSOFT AMBIANCE LIGHTING
LOAD SPACE TRIMCARPET+MOULDING AND CHROMED HANDLE
UNDERSEAT STORAGEWITHOUT UNDER SEAT STORAGE
INSTRUMENT PANEL (CHARACTERISTICS)GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIMGLOSS ARGENT BLACK DECOR
CHILD SEAT ANCHORING POINTSWITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLSSTANDARD AUDIO SYSTEM REMOTE CONTROL
PASSENGER COMPARTMENT SOUNDPROOFING7 KG BULKHEAD SOUNDPROOFING
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF)WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT REAR ADJUSTMENT SPACER
DRIVER SEAT CONTROLMEMORY CTRL DRIVERS FRONT SEAT
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT ELEC CNTRL
DRIVER SEAT ADJUSTMENTDRIV SEAT BACK ANGLE+LUMB ADJ FIXED SIDE UPPER BK
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST
FRONT SEAT ARMREST (OPERATION)FRONT ARMREST MANUAL
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTSEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
DISPLAYDEV HR DISPLAY
COURTESY MIRRORDRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGESTD OIL LEVEL INDICATOR
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER’S + FRONT PASS’S FOOTWELL LIGHTING
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMPWITHOUT DIRECTIONAL LIGHTS
RADIO RECEIVER’RT6’ AUDIO/TELEPHONE REMOTE DISPLAY
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATIONAUTOMATIC AIR CONDITIONNED BI-ZONE
LOAD SPACE STORAGEW/O BOOT TIDY
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFR RR RADAR OBSTACLE DETECTOR + RR CAMERA
LATERAL BLINDSSIDE BLINDS
TRIM ADAPTATIONPVC GEAR LEVER KNOB + LEATHER GAITER
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLSIMPLE CENTRAL LOCKING
STEERING WHEEL4 BRANCH LEATHER STEER WHEEL DECOR METAL
DRIVER’S KNEE AIRBAGWITH KNEE AIRBAG
CHILD OBSERVATION INTERIOR MIRRORWITHOUT INTERIOR CHILD MONITORING MIRROR
SEAT LUMBAR SUPPORT (OPERATION)AUTOMATIC LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB + BLUETOOTH
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR 150 AMP
BATTERYBATTERY L3 720 LDC**************[VIN obfuscated, can be read by forum staff](L3 720 70AH EF 720 EN)
STARTER MOTORSTARTER MOTOR CL 5
SPECIAL LIGHTINGFRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONREDUCED POWER
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT
TRAFFIC SIDEDRIVING ON THE RIGHT-HAND SIDE
SET OF KEYS2 HIGH FREQUENCY REMOTE CONTROL KEYS
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
ADDITIONAL TYPE APPROVAL PLATEW/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNITBSI EVOLUTION
Starfish8828
Thank you very much.
x 1943
Peugeot 308 T9 1.6 BlueHdi VF3**************[VIN obfuscated, can be read by forum staff]
Cover on top of the engine that covers the cam cover and injectors. Has hole cut out for oil filler. Please.
