x 2337
Unread post by MattBLancs »
P.s. wheel arch liner arrived today (quick delivery!) and if the weather permits I'll get it in place tomorrow or Sunday morning.
x 8360
That's intriguing Matt... I've never felt mine regenning although I know from Diagbox interrogations it does happen from time to time...
Huskyxantia
x 901
Unread post by Huskyxantia »
I'm considering the LED mod myself, it would be good to know having a visual aid too that lights up then a mental note of miles when this light come on & off then that can be compared to the diagnostic findings, might make for an interesting set of results.
:-D
x 2337
Here's my most effective "regen awareness mod" - straight through exhaust! 206 exhaust back box fell off (for second or third time - as standard this is a stainless box but a mild steel band around it with the mount on said band. Corrodes a treat!) so I made a straight through with polished 3" stainless tip. (Well it is a GTi (HDi) you know!)
When it was regenerating there was a noticeable booming from the exhaust, particularly at 60mph in 5th, that was not present at all when it was not regenerating
Huskyxantia
x 901
Nice pipe
:-D
x 8360
Very bling :cool:
x 2337
A very rare bit of C5 related "progress" this morning:
Removed it's battery and put it on charge. Almost certainly completely dead, given it was registering a pathetic 1.33 volts before charging. On charge anyway see what happens.
Next, the blue 308 is getting it wheel arch liner upgrade.
Before:
Overview of the under bit
Area of interest
Area of interest
Why I don't think that it's correct:
Hello Monsieur Intercooler
x 2337
But first, need to reinstate a fixing here (rear corner of the arch)
Rivet nut, a size up: M8 is the plan.
x 2337
A bit of blue spray paint (not the right colour but nearer than the previous light blue brush on stuff used in this area!)
Let this dry and then arch liner into place. The captive nuts on the arch liner have had a M6 tap run through them and then a splodge of copper grease each. Tatty and functionality questionable sound insulation moved from old to new arch too.
Huskyxantia
x 901
That intercooler looks , in a scary position 😳
:-D
x 2337
I forgot to do the finished result image, yesterday.
Ta da
x 8085
Nice job Matt but I definitely have mixed feelings about the intercooler being subject to wheelarch crap with the grille in place. While I accept it should get much better airflow I'd be tempted to back that grill with a sieve like sheet to keep the crap off the cooler matrix when reversing! :-D
x 2337
mickthemaverick wrote: 02 Mar 2025, 16:40 Nice job Matt but I definitely have mixed feelings about the intercooler being subject to wheelarch crap with the grille in place. While I accept it should get much better airflow I'd be tempted to back that grill with a sieve like sheet to keep the crap off the cooler matrix when reversing! :-D
Yes, I've resigned myself to the fact wheel spinning in reverse on grit or gravel is off the cards from now on! :lol:
I did think about adding some protection (perforated stainless steel plate would be ideal) but it'll be another day's job.
x 2337
Sorry, just to expand that, in case it's not that clear from the images- the angled blades of the grille point downwards, so would present a solid surface to material ejected from the front of the tyre when the car is moving forward (assuming it moves tangentially from the wheel)
But in reverse, the tangential movement will throw stuff up and straight through the grille's openings. Even more so, when forwards the stuff has to stay in place for about 270° before coming to attack the liner/intercooler, whereas it's only 90° from floor up to grille when reversing.
x 2337
Not to derail the picture thread ( viewtopic.php?p=831817#p831817 ) any further, I was having an idle online search about these hydraulic car ramps.
This Reddit thread really confused me!
Your tractor fell down a cave, what!?
Spoiler: show
I think it is some sort of computer game related discussion!?
These seem very, very cheap
Google shopping says
Strangely the site then claims to be Costco
Costco wholesale????
All distinctly fishy!
Can't find it on Costco's website:
https://www.costco.co.uk/search?searchO ... text=Ramps
Nor on the American version of the site
https://www.costco.com/s?keyword=ramps
So suspect likely a scam.
