- x 8085
Good job all round there Jim, plus you've bitten the bullet on painting which can't be bad!!
Skull
- (Donor 2026)
- x 379
I see your Filthy and raise you a filthier beast
Gary
Gary
- x 8363
And I was OK with it for once and rather pleased I can handle a bit of painting againmickthemaverick wrote: 21 Feb 2025, 18:05 Good job all round there Jim, plus you've bitten the bullet on painting which can't be bad!!![]()
- x 8363
I've had very little time to spend on Bluebell today as much of the day was taken up with officiating at parkrun, patronising our most excellent Methodist Church café and spending time with the family diagnosing their washer/drier. It took out the house main RCD in the middle of Thursday night due to a duff mains RFI suppressor. It's always live and a known fault. One of the Class X suppressor capacitors will have gone short before blowing itself open when the RCD was reset and now with it blown to bits the machine performs faultlessly...
A new suppressor unit - £14 from the bay of E - is on order. Still, against that, I could spend time with my favourite grandchild doing Gruffalo puzzles and reading books - one was all about the adventures of two little characters undergoing potty training... The strapline being 'read this with your toddler and see if they're ready'. Autumn's been dry for ages so the reading of this book was rather academic in her case and for entertainment value alone
She was devastated I was not there to take her to a café! Her parents blame me for creating a café addiction in her... 'Dad, you've created a monster!'
As I've said, a café is my pub and I do spend a lot of time in them feeding my own addictions in the company of either runners., cyclists or both...
So, that left about 90 minutes to play cars... All went well
Bumper back on, washer reservoir refitted, pumps reinstalled and tested...
The rear washer now works a treat
Shame the front one has now decided to pack up
Also a shame the plastic pipe to the rear is so hard it split invisibly where it fits onto the pump outlet port and caused a leak
And to add to the 'fun', Bluebell's alternator is dying
Driving her into the garage I could see the warning light on faintly and a voltmeter across her battery only shows 12V with the engine running...
So it looks like I'll be overhauling another alternator soon. Good job I had a bit of practice with our spare one a while back :
- x 1450
Check the charging voltage at the alternator terminal, just in case something got disturbed during recent works.CitroJim wrote: 22 Feb 2025, 18:01 And to add to the 'fun', Bluebell's alternator is dyingDriving her into the garage I could see the warning light on faintly and a voltmeter across her battery only shows 12V with the engine running...
- x 8363
Good thinking Mike, thanksxantia_v6 wrote: 23 Feb 2025, 05:50 Check the charging voltage at the alternator terminal, just in case something got disturbed during recent works.
- x 1999
Simple, do some work on the cooling system, as you know that cures Citroen screen washer problemsCitroJim wrote: 22 Feb 2025, 18:01 The rear washer now works a treatShame the front one has now decided to pack up
- x 8363
Ha ha yesStickyfinger wrote: 23 Feb 2025, 08:18Simple, do some work on the cooling system, as you know that cures Citroen screen washer problemsCitroJim wrote: 22 Feb 2025, 18:01 The rear washer now works a treatShame the front one has now decided to pack up
- x 2337
Good shout on checking at the alternator terminal. We "diagnosed" a dying alternator on my mates Audi A3 many years ago, removed said alternator and took it to a rebuild place. Bloke put it on his tester *** then handed it back to us "nowt wrong with that!"
Loose main earth terminal
That's going to niggle till I remember.
- Spoiler: show
- x 2337
Nothing at all like Sparkrite! I remembered it was an unusual, strange name. Google and eBay to the rescue!MattBLancs wrote: 23 Feb 2025, 08:38 *** What is the machine called, Sparkrite? Nope.
- Spoiler: show
I've resisted the urge to gain testing capability via a trip over the Pennines to Mirfield!
- x 8363
I've always known those machines as 'Growlers' Matt because they really do growl when in useMattBLancs wrote: 23 Feb 2025, 11:15 Nothing at all like Sparkrite! I remembered it was an unusual, strange name.
No chance to look today as I've spent a lot of the day in the company of a group of equally bonkers friends running nearly 9 miles in thick, deep and slimy mud and across several ploughed fields
Me in full flight across an especially wet and muddy bit...
These were my shoes at the end...
And after they received a jet wash
We enjoyed an awesome post-run social in a superb café that opened especially for us and baked some special cakes for the occasion
They even gave me one to take home for Autumn!
It was all truly awesome and magical
- x 8363
Yes, a very good shout indeed as that's what it is - no volts at the B+ terminal on the alternator from the battery
Access is poor and sight limited so I can't yet see the issue although most likely as I had to work 'blind' to reconnect the starter motor wiring I've left the wiring to the alternator dangling in free space...
On the positive side, I now have fully functioning front and rear washers
Tomorrow I'm out on the bike although the afternoon may give an opportunity for further work... She's nearly there
- x 3306
I have just found out the time The Ultimate Cycling Show will be aired, and it is virtually guaranteed that you will NOT be watching it, Jim. It is at 22:00!
- x 2337
Somewhat inevitable turn of phrase there Jim!CitroJim wrote: 24 Feb 2025, 17:51 ... terminal ... alternator ... battery ... starter motor ... wiring .... alternator ....
Good work on the washers working well!
- x 8363
Not virtually but absolutely rock-solid 100% guaranteed JamesHell Razor5543 wrote: 24 Feb 2025, 21:04 I have just found out the time The Ultimate Cycling Show will be aired, and it is virtually guaranteed that you will NOT be watching it, Jim. It is at 22:00!
MattBLancs wrote: 24 Feb 2025, 21:16Somewhat inevitable turn of phrase there Jim!CitroJim wrote: 24 Feb 2025, 17:51 ... terminal ... alternator ... battery ... starter motor ... wiring .... alternator ....
On the positive side, I now have fully functioning front and rear washers![]()
I'm hoping for some positive news today but first, a bike ride...
