Vintage Audio Activities...
- x 8407
Re: Vintage Audio Activities...
Wow! What an excellent little tool Mike
I like it a lot, especially that it can be used with the components in-situ...
- x 1240
Looks useful Jim - if you do much electronic work, which I don't now.
- x 8407
I still do a bit Peter, just to keep my hand in... I must admit Mike's new tester makes my AVO 8 look a bit dated now...Peter.N. wrote: 13 Feb 2025, 11:25 Looks useful Jim - if you do much electronic work, which I don't now.![]()
I do have a job to do on one of my Leak Stereo 30 amps soon - one channel has gone a bit intermittent due to a duff balance and/or volume pot...
No point in spraying them with Servisol as they have been several times in the past; they're just worn out...
Quite shoddy really and clearly not built to last. They're only about 55 years old...
- x 1240
Try WD40 Jim, I have actually found it better than Servisol. I don't know how old my Servisol is mind, I haven't bought any since I retired and that was 20 years ago!
I bought a Fluke meter about 40 years or more ago, very expensive but having blown up several early digital meters that were about £25 by trying to measure the resistance of the mains (or something similar) I decided to Invest in the Fluke, on of the best things I ever did, you can try to measure the resistance of the mains with impunity and it just screams at you and reverts to its previous setting. They really seem to be indestructible, I only recently disposed of it due to the LCD screen falling apart. I bought a rather larger one off Ebay which I don't use a lot now, probably more on the car than anything, I think I paid about £40 for that but they are still very expensive new.
The old one earned my living for many years. I have a cheapo from Ebay for electrical work and that seems to be pretty good compared to the early digital's.
I just recently bought a Philips EL3542 tape recorder also from Ebay, looks very nice, have been looking for one for years, I bought one new in the '50s and it was about the best domestic machine I ever used, 3 speed, four track and about 15 Khz at three and 3/4 ips and 20 at seven and 1/2.
I have a stack of tapes with such things as David Jacobs Pick of the Pops recorded in the 50s/60s. I will run through when (and if) I get it going and see if I have any famous 'lost tracks'
I am awaiting the belts from Greece!
I went to examine it when it came and found the deck cover screws missing
but inside there was half a broken belt but no other signs of interference. I keep telling myself its analogue and and valve powered
so if I can't repair it I really have lost the plot!
- x 8407
I bought a Fluke meter around 20 years ago and although expensive at the time it's been a great investment - indestructible
I've used WD-40 on 'hopeless case' pots in the past with good results Peter so as these two are just about on the hopeless spectrum, there'll be nothing to loose... Or perhaps GT85 would be better?
That's great on the tape recorder
I had one as a young teenager and they are absolutely superb
In their day they were the one to have.
If you can't fix it then I doubt anybody can. Just watch out for the infamous Philips tar-bombs cunningly masquerading as capacitors
They really are the root of all evil...
- x 1240
I will let you know how I progress (if I do) Practically all the pop music is on Utube anyway but it would be interesting to listen to what else is on there. I know there is at least one episode of 'beyond our Ken' or 'round the horn' I seem to remember. What is GT85 Jim, sounds like jet fuel.
- x 8407
I look forward to news of your progress Peter
Listening to old tapes can be a journey of delightful discovery
Just another flavour of WD-40 really but with added PTFE and particularly liked by the cycling fraternity. AC-90 is another variety...
- x 1240
Oh right thanks.
- x 1461
With a couple of new electrolytics fitted, the Dremel is functioning like new. The hard part was working out how to reassemble it, as I dismantled last year and threw all the bits in a shoebox.xantia_v6 wrote: 13 Feb 2025, 08:55 Today I remembered that I had a 240V Dremel which failed last year, just not running. I found 2 electrolytic capacitors on the control board, a 1?F which measures 770nF with 55? ESR and a 100?F which measures 19?F with 75? ESR. For comparison, a new cap from my junk box has an ESR of 0.5?.
Pity I bought a new one...
- x 8407
- x 8407
A vintage radio at our recent Vintage Event... Note the bottle of Camp Coffee!
For context, it was positioned by a mock-up of an Anderson Shelter as part of a WWII exhibit...
- x 1240
I like it Jim. We had an Anderson shelter in the garden but it kept filling up with water. I had a Morrison shelter in my bedroom, like an iron/steel box for you bed to go in so the roof didn't collapse on you, how you got out if it did I don't know.
- x 3565
How voices travelled the world from a hill in the Midlands
"This year marks the centenary of the opening of the BBC transmitting station at Daventry in Northamptonshire.
It carried the BBC World Service to countries across the world from 1932 to 1992 and was also the site of the world's first national radio transmitter.
So how did this small town in the Midlands become a famous name across the globe?"
"When the BBC sprang into life in 1922, radio broadcasts could only be made over short distances.
The company's chief engineer, Peter Eckersley, believed it was possible to create a long wave transmitter that would serve most of the country.
The BBC decided to find a site for a transmitting station that was situated north of a line between the Severn and the Wash, surrounded by as much land as possible.
Six locations were explored and Borough Hill in Daventry turned out to have the best coverage of land.
The BBC bought 58 acres (23 hectares) of the hill and started work on constructing the station. There was no road to the top, so it built a rack and pinion railway to haul building materials up the slope.
Two 128m (420ft) masts were erected with a lattice of copper wires and aluminium hoops.
The transmission equipment was housed in a spacious hall with cathedral windows in what became known as the 5XX building, external."
An article on the Beeb about the history of broadcasting from Daventry.
Much more here ----> https://www.bbc.co.uk/news/articles/crk6p2n3jrgo
- x 1072
I was wondering why I missed 14pages of this thread, now I remember why......
Champion of Where's CitroJim
- x 1240
Interesting, I have never seen that one but another masterpiece was Droitwich, and 1500 meter half wave dipole, I saw a film of it being built, talk about no health and safety. I was effective though, you can pick it up in the far north of Scotland to Brittany and beyond I expect, and its still there, I pass it quite often.
