x 6945
Huskyxantia wrote: 09 Feb 2025, 12:55 If I'm in the wrong place , sorry ,
Hi Marc part numbers for the injectors VF3**************[VIN obfuscated, can be read by forum staff] Many thanks.
(7) OEM Continental New Injector, part: 9802448680, £644.56
Standard Continental Exchange Injector, part: 1608518380, £491.93
x 2341
Unread post by MattBLancs »
GiveMeABreak wrote: 05 Feb 2025, 10:21
Wheel Arch
(11) Right Wheel Housing Mudguard, part: 9819974080, £128.51
Sorry, a follow on question for you:
Is part 18 (the grille bit) listed with it's own discreet part number ?
Zoomed in on the bit in question
x 6945
Hi Matt, no, it is not listed for your vehicle as was never included for this engine specification. It was only provided for Petrol engines and some 1.5 Diesels, some DV6 diesels and a DW10FC diesel. So not available or not listed against your VIN.
For other models there are 2 parts listed, but both say right side:
9814788380
9819977580
I can't tell you what the differences are though.
Huskyxantia
x 908
Unread post by Huskyxantia »
Dustysweeper wrote: 09 Feb 2025, 11:45 Good morning all. Could I please have the part number for the fuel injectors. No.4 has crapped on me.
The gift that keeps giving eh...🙄
Many thanks.
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
When did your injector go down ? I've problems with my 308cc now runs rough & engine shuddering on tick over. Sounds like an old rattly transit van from the 80s
:-D
Huskyxantia
x 908
GiveMeABreak wrote: 09 Feb 2025, 13:29
Hi Marc part numbers for the injectors VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] Many thanks.
Thanks Marc
:-D
Huskyxantia
x 908
While I'm searching I think id best have part numbers for the seal or is it sleeve plus the washer , same vin , many thanks part 8&9
:-D
x 2341
GiveMeABreak wrote: 09 Feb 2025, 14:22 Hi Matt, no, it is not listed for your vehicle as was never included for this engine specification. It was only provided for Petrol engines and some 1.5 Diesels, some DV6 diesels and a DW10FC diesel. So not available or not listed against your VIN.
9814788380
9819977580
Spot on thanks Marc. :-D
Just in case anyone else is interested, I have worked out what the two numbers above mean! viewtopic.php?p=829424#p829424
GavinPJ
Unread post by GavinPJ »
Good morning lads,
Looking for the part diagram and part numbers for the vacuum pump on VF3**************[VIN obfuscated, can be read by forum staff].
I seem to have a bit of an oil leak. Cheers, Gav.
DaveS
Unread post by DaveS »
Good evening guys,
Bit of a left field request. Could you please share the exploded parts diagram for the aux engine heater with the part number 1343815080 as i am interesting in retrofitting one to my Peugeot boxer. I have the heater already, id just like to use genuine coolant pipes/fittings and the various bits of bracketry. Cheers!
Mihael_M
x 37
Unread post by Mihael_M »
Good evening people,
Looking for the part diagram and part numbers for the oil pump on VF7**************[VIN obfuscated, can be read by forum staff]
Cheers, Mihael
x 1488
Huskyxantia wrote: 09 Feb 2025, 17:07
8 - Engine Injector protector - 1638159980 @ £1.84
9 - Engine injector seal - 198194 @ £4.40
x 1488
GavinPJ wrote: 12 Feb 2025, 08:58 Good morning lads,
Vac pump - 9674192280 - £225.04
x 1488
DaveS wrote: 13 Feb 2025, 00:15 Good evening guys,
That part number isn't found in Service Box - post the VIN of your Boxer so I can see which version it is, then I can see if the heater is shown for that model.
x 1488
Mihael_M wrote: 14 Feb 2025, 17:33 Good evening people,
Cheers, Mihael
Oil pump:
1628955080 - £346.82
Don't know if it comes with a new crank seal already fitted...just in case:
Crank seal - 9820961080 - £48.71
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
GiveMeABreak wrote: 10 Aug 2024, 16:51 No problem, they're not sold separately, so here are the Disc parts (note these are only sold in pairs as must be fitted in pairs when replacing as I'm sure you know already):
(1) Wheel Hub Disc, OEM Original, part: 424946, £158.14 x 2 = £316.28
Cheaper alternative, part: 1619238880, £104.60 x 2 = £209.20
As you can see they contain the disc, hub, ABS ring, bearing and nut as a kit.
Morning. Car passed MOT but had the following advisories:-
Monitor and repair if necessary (advisories):
Rear Brake pad(s) wearing thin Both sides. (1.1.13 (a) (ii))
Front Brake pad(s) wearing thin Both sides. (1.1.13 (a) (ii))
Nearside Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Offside Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Please could I therefore have an update on the above costs if they have chanced since plus:-
Item 2 and 7 on the fiche
PLUS
Cost of discs, pads and sliders for the front please?
For the avoidance of doubt, this is for the 3008.
The rear offside is grinding very badly now (it's embarrassing to drive) so intend to do the job when it's Summer on Thursday or Friday of this week...
Original owner replaced front discs and pads every two years. Leaves me wondering if they were harsh drivers!
