Blower fan running continuously
Wale
Unread post by Wale »
My car heater fan keeps even when I switched off the engine. I need help to locate the blower control module of my DS4 2011, model. Thanks
Wale
Re: Blower fan running continuously
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
x 6945
You have an outstanding After-sales campaign for your vehicle since 01/12/2016.
I suggest you get it booked into the dealers for the work, which will be free of charge.
Ref: NUH - Bonnet
Checking the striker wire mounting on the bonnet. This operation is aimed at guaranteeing the long-term mechanical strength of the bonnet closing system
As for the blower control module, it's on the passenger side of the heater unit. You'll have to remove the side trim no doubt and possibly some parts of the glovebox underside trim to get access.
PaulC5
x 697
Unread post by PaulC5 »
We had a bonnet recall on a C4 and it involved checks and putting a grease filled sticker on the striker wire mounting, I think to help against corrosion which might cause the mounting to come off and the bonnet to fly open, so well worth having done.
