My Citroen Relay 2010 require a new alternator.
The alternators I have seen listed for my vehicle vary in outputs up to 200 amps.
What would be the correct output for my vehicle?
I presume it would be wise to replace belts and tensioners?
Benita
Alternator
- x 6956
Re: Alternator
Your vehicle will be fitted with the correct alternator output for the equipment and options fitted to your specific vehicle. You should always replace it with the correct version as these varied for the cab style and equipment. If you are sure you have the correct factory alternator currently fitted, there should be a plate or label on the alternator to identify it.
Benita
- x 4
Re: Alternator
Thanks Marc
I will let my friendly mechanic aware of this.
Benita
Benita
