x 1491
oli3442 wrote: 20 Jan 2025, 13:21 Hi, please could I have the part number for the brake vacuum pressure sensor if possible.
I have a P0555-12 code 'Braking circuit vacuum sensor short circuit to positive' and good voltage at the connector so was going to try changing this.
Item 3 on this diagram perhaps? Doesn't really tell you where it is!
9677783780 - £81.18
Micko
Unread post by Micko »
RichardW wrote: 23 Jan 2025, 19:58
Micko wrote: 20 Jan 2025, 15:44 Can i get the number for the steering rack.
Vin number is
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
1638434980 - £1791.18 + £300 surcharge for the old unit.
When i search the number i see that a lot of oe numbers can fit the car. I guees its the ecu that i speciel to each specific oe number. Is it possible to switch my original ecu to the new steering rack with a different oe number.
WillyR
(Donor 2026)
x 6
Re: Grand Picasso II (B78) Driver Door Mirror (RHS UK) - Part number Please
Unread post by WillyR »
RichardW wrote: 23 Jan 2025, 20:06
WillyR wrote: 21 Jan 2025, 13:08 Good afternoon everyone,
I hope I have made this request in the right place.... The Motor mechanism on my driver door mirror has stopped working - everything else still works OK. I suffered a cable break last year in this mirror, which I fixed, noticing the the loom down into the door was far too tight, so I managed to free it up quite a bit, but the mirror is determined to punish me for something. I have investigated many pre-owned mirrors but the advertisers all skip out several of the functions, and I am loath to have to swap bits around too much.
Please can you give me the PSA part number (2015 model 2.0 ehDi 150bhp EAT6 Exclusive) - VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Sincere apologies if I have posted this request in the wrong place.
WillyR
Yes, right place!
There was a 7 missing from the VIN after the VF - I've corrected it.
RH Mirror - 1610545980 - £909.44
Hi RchardW,
Thank you so much for the requested info. I have no idea how the extra digit found its way into my VIN Number (I can't even find the PM any longer) - it was OK whn I Reviewed it before sending it and of course I couldnt see it after it had gone as the number was obfuscated. I have only just seen this answer from you for the very first time.
Incidentally, when I had the first problem with this mirror back in 2024, the price was quoted by my local Citroen Garage (no longer trading) as £550-odd. Nice price rise this year... NOT
Sincere apologies to you and myglaren.
Regards
WillyR
2015 (Jul) C4 Grand Picasso 2.0 Bluehdi 150 EAT6 Exclusive+ now running on 17" wheels - SO MUCH MORE COMFORTABLE AND SMOOTH THAN 18" - AND better fuel economy :) =D>
macyng
Unread post by macyng »
Hello, sorry if this topic does not belong here and especially my English, I use a translator, could someone tell me what would be the correct staples or clips for the door trim for a Citroen DS5? Thank you.
quintet
x 44
Unread post by quintet »
macyng wrote: 24 Jan 2025, 07:27 Hello, sorry if this topic does not belong here and especially my English, I use a translator, could someone tell me what would be the correct staples or clips for the door trim for a Citroen DS5? Thank you.
Hello, the english translation is working fine, if it's the actual part numbers you require then to gain this information you would need to become a "donor" for a small fee. For example you will see "Donor 2023/24/25" located under the forum users names on this thread. To become a "donor" look here > viewtopic.php?t=69962
Music keeps me going.
quintet
x 44
Hello, could i please get the part numbers for the following items,
EGR valve, Metal Gasket and metal pipe clamp to suit aforementioned.
This car tend to throw up a bit of a curve ball as it's got later spec equipment but in a phase one body so it must have been built right on the crossover in 2005 (eg it does NOT have a doser valve)
VF3**************[VIN obfuscated, can be read by forum staff] RP 1033489
Thank you.
x 1491
quintet wrote: 24 Jan 2025, 23:15 Hello, could i please get the part numbers for the following items,
Thank you.
EGR Valve - 1628JZ - no longer available, was £364.24
Gasket - 16282N - £3.19
Tube clamp - 16283J - £24.78
WillyR
(Donor 2026)
x 6
Thank you, kind Sir.... I just found this in my junk Folder, so my thanks come rather late, in total opposition to the speedy delivery of yours
Regards
WillyR
quintet
x 44
RichardW wrote: 25 Jan 2025, 10:18
VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] RP 1033489
Thank you.
Hello, could i get clarification that all EGR valve's suitable for the 2.0 HDI are the same as there's a number of component's in that image which my car does not have fitted such as the Air Mixer Unit Assembly (#17) Exhaust Gas Recirculation Solenoid Valves (#6 x2 in image) and some of their associated pipework. It is likely to have the Pollution Control depress(ure?) hose (#10) but I currently don't know where this ends.
Thank you.
x 1491
I can't guarantee it's all versions of the engine, but it is widely used, a search on the part no in the Peugeot section brings up matches in:
Information about the search
1 document(s) found for 206
2 document(s) found for 306 (RESTYLING)
1 document(s) found for 307
2 document(s) found for 307 RESTYLING
1 document(s) found for 406
4 document(s) found for 406 (RESTYLING)
1 document(s) found for 607
1 document(s) found for 806
6 document(s) found for EXPERT 1 & 2 (U6)
2 document(s) found for PARTNER
1 document(s) found for PARTNER VP (M59)
1 document(s) found for PARTNER VU (M59)
Micko
Can i get the number for front wheel bearing
GavinPJ
Unread post by GavinPJ »
Morning lads,
Can I get the diagram and parts list for the bonnet and bonnet stay etc for FL036205.
Also the part number for the screen wash bottle cap.
Thanks,
x 1940
Is 9818559380 still the part number for the Adblue tank for our 308? The one that was fitted at 69,000 miles in 2020 has failed on the pump. Only at 93,000 miles now and it's been giving me notice by needing reinitialisation of the Denox System occasionally since 2023. I'd like to try repairing the tank but don't have the time. Disappointing.
VIN VF3**************[VIN obfuscated, can be read by forum staff]
x 6945
Micko wrote: 27 Jan 2025, 11:43 Can i get the number for front wheel bearing
(8) Front Wheel Hub, part: 9670367680, £164.66
x 6945
GavinPJ wrote: 28 Jan 2025, 09:21 Morning lads,
Thanks,
Gavin, please don't provide registration in future as that's useless to us, we require the VIN. If this is for your vehicle ending in 612, then:
(1) Bonnet, part: 7901P3, £1052.71
(6) Bonnet Stay, part: 792764, £20.51
Screenwash Cap, part: 643237, £11.96
