Evening all
Just putting a 2.0 HDI DW10CTED4 back together and need a bit of info.
When I started working on this I found 2 injectors had been leaking and had filled the area around the injectors and wiring with carbon and tar,
I had to chisel my way in and the 2 injector harness's came out in pieces.
Everything is now cleaned and 2 new wiring etc, there is 2 the same and I can't figure out where they go.. The 4 injector ends are the same and there is 2 plugs to connect to the engine loom and they could go on either also.
A picture of the routing or any info welcome
The grey plugs feed 2 injectors but obviously need to feed the correct ones
Thanx
3008 Injectoer wiring harness's
Steve Walsh
- x 518
- x 6947
Re: 3008 Injectoer wiring harness's
Steve, not sure if the injector harness diagram is of any use?
Steve Walsh
- x 518
Thanx Marc, I had that diagram but no clarity as to which goes where, Got it sussed now and now waiting for injectors coming back from recon, I have never known a car with so many faults and problems and still running... Ito 1200 euros for parts up to now, hope I am near the end...
Cheers
Steve
Cheers
Steve
